Modern UI
Moderator: agryson
HakanSeven12
Re: Modern UI
Postby HakanSeven12 » Tue Mar 02, 2021 9:04 am
I removed workbench names from section names. You can see difference at the screenshot.
https://www.patreon.com/posts/48224139
Section Names.png (220.51 KiB) Viewed 564 times
MisterMaker
Re: Modern UI
Postby MisterMaker » Thu Mar 04, 2021 7:15 pm
Mesh toolbar look awesome now,really quick fix :o ! :
2021-03-04 20_13_50-.png (133.96 KiB) Viewed 483 times
HakanSeven12
Re: Modern UI
Postby HakanSeven12 » Thu Mar 04, 2021 7:49 pm
Nice ;)
Joan
Re: Modern UI
Postby Joan » Tue May 04, 2021 1:23 am
Very nice work. 8-)
Though, I come from Inventor and have started with it when they still had vertical "workbenches" on the left side of the screen and never moved on to the GUI design change to have all toolbars at the upper edge of a window/screen that MS favored.
Nowadays with widescreen monitors I always favor having a bit more vertical space, which is why I still run it like this after all those years (and try to set up other CAD tools similarly if possible).
My question thus - can your Modern UI do this too - vertical toolbars/workbenches?
I tried, but had no luck. It seems to be stuck at the top edge of the screen :-(
Is there any setting I miss?
Thanks
Inventor with vertical 'workbenches' and maximum vertical screen estate (not even file/edit/view/etc. menu)
FC 0.20 rev 24787 64Bit
Re: Modern UI
Postby Kunda1 » Tue May 04, 2021 1:57 am
I've seen vertical workbench toolbars on zolko's (the assembly4 dev's) GUI
as seen in this screenshotImage
HakanSeven12
Re: Modern UI
Postby HakanSeven12 » Tue May 04, 2021 4:10 am
zisoft
Re: Modern UI
Postby zisoft » Tue May 04, 2021 6:47 am
This is TabBar: https://forum.freecadweb.org/viewtopic.php?t=13368
Joan
Re: Modern UI
Postby Joan » Tue May 04, 2021 1:26 pm
Maybe you want to look at this https://forum.freecadweb.org/viewtopic.php?f=8&t=55779
Ah, thx for the pointer. Much appreciated. Looks more where I would like to go it seems :)
