Start Page Redesign
Moderator: agryson
RogerK
Re: Start Page Redesign
Postby RogerK » Wed Nov 21, 2018 7:26 pm
Hi all
I have also observed a numbers of issues. As discussed before, the Notes aren't saved on my machine too. The Folder webdata is present, but inside no localstorage file is created. Everytime the Start page is closed and reopened, the Notes are gone.
Besides this, there is a bug regarding the path to the python libraries. When the conada image is stored in the D: Drive, the libraries are not found because they are always searched in the C: drive, this happend in different location, for example when creating a new file or opening a file or switch to another tab:
Also mentoined earlier, the Icon's are missing on all pages on my machine (conda image):
When Windows is running in 4K Resolution, there are rendering issues with the page (but it's fine in 2K, as shown above):
Conda Image:
Version: 0.18.15248 (Git)
Hash: 608d42d3cdce307b585534adfdae9c9af7304436
Python version: 3.6.6
Qt version: 5.6.2
Locale: German/Switzerland (de_CH)
Kind regards
Roger
yorik
Site Admin
Postby yorik » Wed Nov 21, 2018 9:35 pm
Ah thanks. This is getting us somewhere already. I'm trying to figure out why C: is used instead of the correct unit, but I see nothing that could make that happen in the code... that might be a problem with conda packaging.
For 4K resolutions I unfortunately have no screen to test :) Maybe we should add some specific css rules for it, I'll look at how that is done..
RogerK
Postby RogerK » Thu Nov 22, 2018 5:28 pm
I have downloaded the current 15252 builds, both conda and the legacy x64 one. Your suspicion was correct, it's related to the conda build. The conda build has the issue with the wrong drive letter and the legacy one works correct. Also the not displayed images must be related to the conda build, the legacy build shows all images on the documents and help pages.
With the 252 build the notpad is now working, the file is created and the notes are stored. The patch from triplus fixed this.
bitacovir
Postby bitacovir » Mon Dec 17, 2018 3:03 pm
Hi. Just for the records. The Note function is working normally. It keeps the notes across different sessions in my windows.
Well done!
Version: 0.18.15417 (Git)
Hash: cc0ea5571e0bc451d415bd8624df0b3fa40f447b
Python version: 2.7.14
OCC version: 7.2.0
::bitacovir::
My personal web site
My GitHub repository
My old Blog
Mini Airflow Tunnel Project
yorik
Site Admin
Postby yorik » Tue Dec 18, 2018 12:49 pm
It's not for me with qt5... But there seem to be some problems with some versions of qt5, that I couldn't sort out yet. But in any case it's not a very important function and it's turned off by default, so it shouldn't hinder the release or anything
hammax
Postby hammax » Thu Jan 03, 2019 2:49 pm
Win10_32
FC.18.15536 and previous (bug report)
… clicking in the Start Page on an icon/preview of some file stored in the Gallery to open it,
there comes this popup without any opening.
The files are OK and can be opened direct from their folder.
Syres
Postby Syres » Thu Jan 03, 2019 4:21 pm
Can confirm 'No module named urrlib' error with:
OS: Windows 7
Version: 0.18.15536 (Git)
Hash: 98ebeaa198df945ba666c15912c6caf95920f0ef
OCC version: 7.2.0
Look like it's just a typo in /data/Mod/Start/StartPage/LoadCustom.py (should be urllib not urrlib on line from urrlib import unquote) :
import FreeCAD,FreeCADGui,os,sys
if sys.version_info.major < 3:
else:
    from urllib.parse import unquote
NormandC
Postby NormandC » Fri Jan 04, 2019 4:24 am
You're right, editing the file as you suggest fixes it for me.
Site Admin
Postby wmayer » Fri Jan 04, 2019 9:57 am
looo
Postby looo » Fri Jan 04, 2019 10:41 am
I also do not know what the problem is here. But I know that conda replaces hard-coded paths during package installation. So paths should be correct if FreeCAD is installed with conda. I guess this should work on either C: or D:. This is not true for the bundle available from the github-release page. I don't know how paths are handled there.
For debugging please post the output of:
import FreeCAD as App
print(App.getHomePath())
print(App.getResourceDir())
print(App.getUserAppDataDir())
