UI/UX suggestions for Addon Installer
Moderator: agryson
kkremitzki
Re: Soft UI/UX suggestions for Macro Addon Installer
Postby kkremitzki » Fri Mar 17, 2017 4:05 pm
I plan on doing some more work on this project over the next few weeks, and I have a quick question for you all.
Right now, this tool's menu text is "Addon manager". Originally, when it was a macro, it was "Addons installer", but I unilaterally changed it when I added that code to FreeCAD's core since I don't believe the extra 's' is grammatically correct, and I was curious if anyone would say anything. In truth, also, "add-on" should be hyphenated.
Now, however, it doesn't really seem like anyone noticed, so I'd like to have a discussion on the topic. What should the tool say or be called? For comparison,
- Firefox just has a button labeled "Add-ons"
- LibreOffice has an "Extension Manager"
- QGIS has "Manage and install plugins"
yorik
Site Admin
Postby yorik » Fri Mar 17, 2017 5:23 pm
This is a complicated matter... Even more that FreeCAD uses the concept internally too (the modules are in a sense also plug-ins). And the "add-ons" are in fact workbenches and macros, that can sometimes also be simply FreeCAD modules... Doh :)
I'm not sure we can find something that will definitely solve the question :D
DeepSOIC
Postby DeepSOIC » Fri Mar 17, 2017 7:29 pm
"Addon manager" sounds all right to me. It makes it more-or-less clear they are not part of freecad itself.
Addon (or plug-in) may be is a module, but a module is not necessarily an add-on. See, you can't remove Part from FreeCAD with add-on manager, and I think it is right. "Extension" means a different thing in FreeCAD already, so it's taken.
Postby Kunda1 » Wed Mar 21, 2018 10:45 pm
How about we re-use the QGIS .ui for the addon manager ?
https://github.com/qgis/QGIS/blob/maste ... gerbase.ui
Re: UI/UX suggestions for Addon Installer
Postby Kunda1 » Thu Mar 22, 2018 2:05 pm
Maybe useful: updating check for external Workbenches https://forum.freecadweb.org/viewtopic.php?f=10&t=27621
easyw-fc wrote:ping
@easyw-fc is this methodology could be utilized in this possible next iteration of the addon manager (mentioned in my previous post) ?
easyw-fc
Postby easyw-fc » Thu Mar 22, 2018 5:49 pm
easyw-fc wrote:ping
what I do for my checking is:
1) having the commit number defined as a variable inside the WB
2) get the main GH web page of the WB when the WB is activated (if the checking is enabled)
3) extract from the web page the commits number and check if compares with the one coded inside the WB
This is the simpler method I found to check if the installed WB is up to date with the one at GH...
May be there are other simpler/better methods
:D
Maurice
Postby Kunda1 » Mon Apr 02, 2018 2:10 pm
Anyone open to mentoring me attaching the FC backend code to this QGIS frontend template ?
yorik
Site Admin
Postby yorik » Mon Apr 02, 2018 5:02 pm
I think most of the addon manager script code would need to be redone... Are you sure this is the best way? Personally I would find more efficient to extend the existing one to add the missing features you need from the QGis one.
Plus there are other points to solve first: How will you detect new workbenches? And invalid ones? How would the vote system work? You would need a server somewhere with some server-side code running on it, to register the votes. How will you make sure a person doesn't vote a hundred times? Also, what would be the use of a vote system?
There is also the problem that for people without python-git we currently don't have a system to detect if an update is available...
Postby Kunda1 » Mon Apr 02, 2018 5:41 pm
How would the vote system work? You would need a server somewhere with some server-side code running on it, to register the votes. How will you make sure a person doesn't vote a hundred times? Also, what would be the use of a vote system?.
I'd probably forego the voting system.
I wouldn't add that functionality yet. I'd leave it de-activated till we figure that out.
Fair enough. I'm just not sure how to extend our current addon. Qt Designer isn't as intuitive as I would like it to be.
easyw-fc
Postby easyw-fc » Tue Apr 03, 2018 12:46 pm
what I do with my update checker for my WBs is using urllib2 or urllib (for py3) to fetch the GH page and get the commits number. Then I compare this value with the one written in the WB itself.
Both libs should be available in the default python installation.
The developer has only to align the internal saved commit nbr variable to the next commit number, before upate the WB.
More details here:
