Command panel
Moderator: agryson
jaisejames
Re: Command panel
Postby jaisejames » Wed Jan 09, 2019 5:26 am
Is any possibility to extend as global panel?. useful for me to use array in other workbenches. :)
triplus
Re: Command panel
Postby triplus » Wed Jan 09, 2019 2:26 pm
Yes. Global panel mode was already implemented and will therefore get released soon. After "UUID/Domain functionality", as Global panel mode uses it.
jrdrukin
Command Panel
Postby jrdrukin » Fri Jan 18, 2019 2:58 am
I have found the command panel to be a very nice customization feature. It can show you most functions in FC and access them with just one click. However, noticed some unusual behaviour.
Command panel icons move when open a sketch or use other function:
I am wondering if anyone else has seen this behavior?
Thank you, Jerry/jrdrukin
Command Panel - 001 Screenshot 2019-01-17 18.00.46.png (153.21 KiB) Viewed 845 times
Command Panel - 002 Screenshot 2019-01-17 18.03.45.png (153.45 KiB) Viewed 845 times
Version: 0.18.15639 (Git)
Hash: 3f51e25b26ed19a2b17e218c8a0d438eb2e13b26
Python version: 2.7.14
OCC version: 7.2.0
triplus
Re: Command panel
Postby triplus » Tue Jan 22, 2019 9:16 pm
Menu container.png (38.98 KiB) Viewed 763 times
There is now a possibility to use a dock widget or an invokable menu. As a container for commands. Invoke shortcut for menu container can be customized with ShortCuts module for FreeCAD. I do imagine frequent users will likely prefer to set a single key (global) shortcut.
P.S. Jerry thanks for testing and reporting back. I noticed such behavior in the past myself, but didn't yet investigate any possible solutions. Will bump the priority.
triplus
Re: Command panel
Postby triplus » Sun Jan 27, 2019 11:19 pm
Support for basic domain name system got implemented. Here is how a typical domain name for a menu looks like when created by:
Developer:
CPMenu.System.PartWorkbench.PartSolids
User:
CPMenu.User.StartWorkbench.89315827-0826-4a49-9181-3a888f20e8d9
Edit menu section in Preferences got updated and started utilizing domain name system support:
triplus
Re: Command panel
Postby triplus » Sat Feb 02, 2019 9:26 pm
Sometimes it is desired, to use the same set of commands through all workbenches. Global panel mode now provides such capability.
regis
Re: Command panel
Postby regis » Mon Feb 04, 2019 9:53 pm
Hello, I was testing this command panel for better familiarity. I like it but i may be missing something out in it's understanding. I tried to add the survey and addon manager in the top tool bars as a test to get started with but it didn't work. What am I missing?
Another question I have is that, how do you recognise if any of these dialog windows are made 1. with Qt designer (if yes is there a template?) and or 2. is made with Python? 3. Made with C++?
Screenshot from 2019-02-04 16-48-00.png (287.52 KiB) Viewed 631 times
triplus
Re: Command panel
Postby triplus » Mon Feb 04, 2019 10:47 pm
Soon an API is to be added. A set of predefined commands and menus for individual workbench will therefore became a possibility. In addition, when no such definitions will be provided, by developer, some commands will get extracted from the workbench toolbars. As a convenience, to always see some commands by default. That didn't yet happen and ATM you get an empty Commands panel by default as the result.
Therefore what you need to do next is to set a default menu for BIM workbench (or globally if Global panel mode is enabled). You can do that by clicking on a checkbox, located left from the menu combo box (Default).
There is no documentation available yet, but as Command panel is nearly done, that will get sorted out after. In addition it's nice to get such feedback, as i get a sense of what potential end users find intuitive or not.
In general you i guess need to take a look in the code for clues. For example:
https://github.com/triplus/CommandPanel
No C++, no .ui files just Python (and PySide).
regis
Re: Command panel
Postby regis » Tue Feb 05, 2019 12:51 am
Thanks a bunch. Still testing. Will give you my feedback at somepoint but so far I like it and it think it is pretty usefull already.
By the way is there a General Icon Bank somewhere? I see alot of people on their individual macro or WB create a seperate folder for icons.
triplus
Re: Command panel
Postby triplus » Tue Feb 05, 2019 6:32 pm
You're welcome.
For default set of modules:
https://www.freecadweb.org/wiki/Artwork
from PySide import QtGui
btn = QtGui.QToolButton()
icon = QtGui.QIcon(":/icons/freecad")
btn.setIcon(icon)
btn.show()
Default set of modules usually provide icons in resource collection files. In an example it is demontrated on how you can access and use an icon from a resource collection file, path set to :/icons/freecad. From FreeCAD Python console, macro or a module.
After updating command panel to the latest changes this should improve.
