Command panel
Moderator: agryson
triplus
Re: Command panel
Postby triplus » Wed Feb 27, 2019 3:46 pm
Using the command panel for the first time (per workbench), now offers some commands by default. A combination of global menus and commands extracted from toolbars is being used.
A set of definitions, for predefining global menus, is now provided, utilizing new command panel API. Module developers can make use of the API in the same way. Example for Start workbench:
import CommandPanel as cp
workbench = "StartWorkbench"
# workbench = "GlobalPanel"                         # Global panel
menuNavigation = {
    "workbench": workbench,                         # Mandatory
    "uuid": "StartNavigation",                      # Mandatory
    "name": "Navigation",
    "commands": [
        "Web_OpenWebsite",
        "Start_StartPage",
        "Web_BrowserBack",
        "Web_BrowserNext",
        "Web_BrowserRefresh",
        "Web_BrowserStop",
        "Web_BrowserZoomIn",
        "Web_BrowserZoomOut"]}
domainNavigation = cp.addMenu(menuNavigation)       # Add menuNavigation
menuDefault = {
    "uuid": "StartDefault",
    "name": "Default",
    "default": True,                                # Set as default menu
    "commands": [
        "CPGlobalDefault",                          # Add global default
        domainNavigation]}                          # Add menuNavigation
cp.addMenu(menuDefault)
Such definitions can get imported from InitGui.py and are deleted when closing FreeCAD. If user didn't set any menu as a default menu, system provided menu will get used, the one set as a default menu by developer.
triplus
Re: Command panel
Postby triplus » Sun Mar 03, 2019 12:50 pm
  • Two new commands have been implemented. For renaming and copying menus.
  • In copy menu dialog an addition of Toolbars section was added.
  • Expected result when copying commands from Macro toolbar into a new menu.
  • Renaming the created menu.
P.S. I consider command panel module for FreeCAD as being feature complete. All planned features form the ToDo list have been implemented!
Re: Command panel
Postby Kunda1 » Sun Mar 03, 2019 1:47 pm
Great progress so far @triplus :clap:
triplus
Re: Command panel
Postby triplus » Sun Mar 03, 2019 4:40 pm
Thanks.
efyx
Re: Command panel
Postby efyx » Wed Mar 06, 2019 11:27 am
I cannot invoke Command panel... newest build of 0.18 version. I changed in shortcuts inovke key, but also not working. Something broke?
triplus
Re: Command panel
Postby triplus » Fri Mar 08, 2019 4:55 pm
You need to enable the Menu (container) options first.
https://forum.freecadweb.org/viewtopic. ... 50#p281768
Re: Command panel
Postby Kunda1 » Sun Sep 15, 2019 3:27 pm
Issue when trying to resize command panel, it won't resize below a certain threshold and therefore takes up 'real estate'
OS: Manjaro Linux (XFCE/xfce)
Version: 0.19.18213 (Git) AppImage
Hash: 22babc09954ac6fda9135ee71d68550921659b1c
Python version: 3.7.3
Qt version: 5.12.1
Latest version of Command Panel:
commit c28ae6ee1345d39dad58560dfabc882a28772d2e (HEAD -> master, origin/master, origin/HEAD)
Author: triplus <redacted>
Date: Mon Mar 18 22:31:13 2019 +0100
Move Accessories menu from tools menu to menu bar
triplus
Re: Command panel
Postby triplus » Fri Oct 04, 2019 12:03 pm
Will take a look in the following days.
P.S. I plan to add some command definitions, for some commonly used modules, as the API is there. And i doubt other developers will try to do that in foreseeable future. I am thinking the layout of commands will follow the toolbars, but commands will get added to menus (as groups). Therefore by default a lot less space will get used and an individual menu can get expanded, when needed.
