Icons for Part and Group
Moderator: agryson
ickby
Postby ickby » Fri Jul 28, 2017 5:27 pm
Hello Graphic-Wizards,
I'm looking for icons for the 0.17 Part as well as for the normal Group, both use the same one currently. It is the system Icon for a folder, so it looks totally different on every system, but a folder does imho not represent the function of the Part very well. A folder is appropriate for the normal Group, so this would in general fit. However, the icon is not usable for the toolbar button. I think there must be a resemblance between tool button and tree objects, and as I want to introduce a toolbar button for group too it must be a normal icon.
So if anyone could make two nice icon I would be glad and thankful :)
DeepSOIC
Re: Icons for Part and Group
Postby DeepSOIC » Fri Jul 28, 2017 8:31 pm
DeepSOIC
Postby DeepSOIC » Fri Jul 28, 2017 8:34 pm
This one I use in Part-o-magic, feel free to use if it fits
And as for Group icon, IMO the folder one does it quite well.
Postby chrisb » Sat Jul 29, 2017 6:24 am
+1
ickby
Postby ickby » Sat Jul 29, 2017 7:40 am
thanks for the icons. I like the part one and think I will use it. For group the folder is fine in general, however, currently it is the system icon. Hence it cant be used for the toolbar button. Therefore i would like a freecad style icon that can be used in the tree and the button.
yorik
Site Admin
Postby yorik » Sat Jul 29, 2017 3:18 pm
I think you should be able to use the system folder icon as a toolbar icon,no? It's easy to obtain it as a QPixmap I think... Maybe childish, but personally I like having "folders" in the tree :)
What about joining the folder icon with a part icon, for App Part? That can be done with Qt code, so it can use the system folder icon too. Something like this:
app-folder.svg
(12.17 KiB) Downloaded 68 times
pablogil
Postby pablogil » Thu Aug 03, 2017 11:50 pm
Here you have a Part icon I designed time ago by your request... I see you skipped my answer :?
For groups, I also like the idea of having the "folder" one, but if you prefer to unify OSs then I can design it.
BTW, if you skipped my answer you also skipped the other icons @agryson and me designed for axis and planes. I have attached them to this post in case you also skipped them ;)
axis and planes.zip
(35.95 KiB) Downloaded 37 times
Part.svg
(9.3 KiB) Downloaded 83 times
Dark and Light stylesheets v2.0 to theme your FreeCAD UI, more information here
NormandC
Postby NormandC » Sat Aug 05, 2017 4:08 pm
This icon does not represent what the Part container is for. It may be counter-intuitive, but Part is more an assembly than a single part. Part can contain multiple objects including bodies, Part objects, Arch objects, 2D geometry, almost anything.
Why did you go with such a "flat" projection? An axonometric projection would better convey the 3 dimensions...
NormandC
Postby NormandC » Sat Aug 05, 2017 4:21 pm
For those who wonder what the axes & planes icons look like:
I don't understand why the X axis is pointing to the lower left while the Y axis is pointing to the right. It is very confusing because that's not how they are placed in FreeCAD.
Have a look at the axis cross from FreeCAD's 3D view when the view is set to axonometric:
NormandC wrote:Why did you go with such a "flat" projection?
EDIT: I just noticed that's how the existing "Origin" icon looks like. Sorry! I wonder where it can be found in the source code?
NormandC
Postby NormandC » Sat Aug 05, 2017 6:11 pm
Mods, maybe the plane/axis icon discussion should be split off into a separate topic?
I was curious to see what the big commercial CAD packages do for origin/plane/axis icons.
Turns out they have a single plane icon and a single axis icon (some don't show axes). Inventor regroups them under an Origin group, it's a folder icon.
Catia: http://i.ytimg.com/vi/OxX3sOzKROE/maxresdefault.jpg
Autodesk Inventor: https://i.ytimg.com/vi/dilWO1xSr3Y/maxresdefault.jpg
Solidworks: http://blogs.solidworks.com/solidworksb ... 44x700.png
PTC Creo: http://www.inneo.co.uk/fileadmin/inneo/ ... tmetal.png
Solid Edge (really old capture): http://www.kisssoft.ch/english/products ... creen2.gif
My question: do we really need separate icons for each of the standard axes and planes? For planes, why not just show a slanted square, like most CAD programs do?
Something simple like this:
After all, there is a single icon for datum plane.
For the Axis, not sure... A slanted line does not tell much. Maybe if it's contained in a greyed out plane?
Just throwing things out there. I've never been much of an icon designer. ;)
PartDesign_Std_Axis_nc1.svg
(7.5 KiB) Downloaded 100 times
PartDesign_Std_Plane_nc1.svg
(6.76 KiB) Downloaded 105 times
