PieMenu (v2.0)
Moderator: agryson
Re: PieMenu (v2.0)
Postby NormandC » Mon Oct 15, 2018 4:12 pm
Some add-on workbenches have their own dedicated pages on the FreeCAD wiki. Yorik has stated his wish that all add-ons be documented on the wiki. I think it would be acceptable (and desirable) to have your documentation on the FreeCAD wiki, where it can be translated into other languages.
If you decide to write your documentation on your Github repo, we can probably just copy its content (with minor syntax changes) to the FreeCAD wiki, that is of course, if the license you choose allows it.
Which reminds me that apart from the Release notes 0.17, the Navigation Indicator is not documented anywhere in the wiki... Will put that on my todo list.
triplus
Re: PieMenu (v2.0)
Postby triplus » Tue Oct 16, 2018 5:59 pm
The plan i had a while back is to write the documentation by using (as it is portable):
https://tiddlywiki.com/
P.S. After indeed i will likely ask for help on properly placing this information/documentation on FreeCAD Wiki. This will likely happen early in 2019 as hopefully all my modules should be done by then. And evaluation on what developed functionality to upstream (as a part of the Tux module) should make things clearer (from the documentation perspective).
adrianinsaval
Re: PieMenu (v2.0)
Postby adrianinsaval » Fri May 17, 2019 3:39 am
So, is this still being made?
Jee-Bee
Re: PieMenu (v2.0)
Postby Jee-Bee » Fri May 17, 2019 5:29 am
vocx
Re: PieMenu (v2.0)
Postby vocx » Sat May 18, 2019 5:53 am
The PieMenu addon is installable from the Addon Manager. It will be in the Workbenches tab, although it is not really a complete workbench, just a graphical enhancement.
The code lives in its own repository, https://github.com/triplus/PieMenu But you don't have to install it manually, you can just use the Addon Manager.
pablogil
Re: PieMenu (v2.0)
Postby pablogil » Sat May 18, 2019 10:36 pm
I guess adrianinsaval is referring to how is going the development of version 2.0, not the actual one...
triplus
Re: PieMenu (v2.0)
Postby triplus » Fri Jun 14, 2019 12:49 pm
I will be able to dedicate some free time again towards finishing PieMenu v 2.0. Current status is back end was developed during command panel development and front end related tasks all went through the prototype stage. In short i am still committed in reaching the initially set goals.
pablogil
Re: PieMenu (v2.0)
Postby pablogil » Fri Jun 14, 2019 6:49 pm
Nice to read it. I’m still very interested in this addon, it will surely boost designers work.
Cheers
triplus
Re: PieMenu (v2.0)
Postby triplus » Mon Aug 12, 2019 4:23 pm
An unplanned project emerged that i had to finish in the past month. As a result i couldn't dedicate any free time to the pie menu development. Hopefully this will change now and further progress regarding pie menu will be made.
Use Case: use pie menu as a workbench selector.
pablogil
Re: PieMenu (v2.0)
Postby pablogil » Mon Aug 12, 2019 9:46 pm
As always I'm eagerly waiting for your PieMenu v2.0 because it could be a game changer when talking about FC usability so I'll be tuned ;)
