PieMenu (v2.0)
triplus
Re: PieMenu (v2.0)
Post by triplus »
ifohancroft wrote: Tue Apr 21, 2020 2:28 pm How to do it without having to install/have installed the ShortCuts module?
Look above at the answer provided by @adrianinsaval.
pablogil
Re: PieMenu (v2.0)
Post by pablogil »
Hi triplus,
Two years ago you started this thread, how is Piemenu 2.0 development status?
Me and, I bet lot more users, are still eagerly waiting for it. ;)
Cheers
Dark and Light stylesheets v2.0 to theme your FreeCAD UI, more information here
Davide_sd
Re: PieMenu (v2.0)
Post by Davide_sd »
Is it possible to change the current access key (TAB) to something else? I tend to use TAB to quickly move across textboxes to edit preferences on parts/sketches (for example, creating a datum plane and settings the offsets/rotations without having to constantly click the textboxes). When PieMenu is active, I can't do that.
Syres
Re: PieMenu (v2.0)
Post by Syres »
Davide_sd wrote: Fri Feb 12, 2021 5:12 pm Is it possible to change the current access key (TAB) to something else?
@triplus hasn't been active recently so my take would be to change line 1905 of InitGui.py in the %APPDATA%\FreeCAD\Roaming\Mod\PieMenu folder from:
        actionKey.setShortcut(QtGui.QKeySequence("TAB"))
to reflect another key but make sure it doesn't clash with another part of FreeCAD.
ChristophS
Re: PieMenu (v2.0)
Post by ChristophS »
Hello everybody,
this is my first post on this forum starting with a question regarding the PieMenu.
As soon as I hit the TAB button the hole screen turns into opaque black. How to change this behavior?
Re: PieMenu (v2.0)
Post by Kunda1 »
ChristophS wrote: Wed Apr 21, 2021 6:04 pm As soon as I hit the TAB button the hole screen turns into opaque black. How to change this behavior?
This sounds a like a display driver issue. Does that happen in any other context when using FreeCAD ?
See Known Issues thread
ChristophS
Re: PieMenu (v2.0)
That's the only and first appearance like this in FreeCAD.
Re: PieMenu (v2.0)
Post by Kunda1 »
If you want the most up to date PieMenu functionality, you may want to consider using realthunder's LinkStage3 branch. He has souped up @triplus's PieMenu addon (which is what you see in this thread)
You can download LinkStage3 from: https://github.com/realthunder/FreeCAD_ ... 3/releases
Here's an example of realthunder's enhancements:
https://www.youtube.com/watch?v=tq-FJH0p9aE
ChristophS
Re: PieMenu (v2.0)
I installed that version. It didn't change that behavior.
Re: PieMenu (v2.0)
Post by Kunda1 »
ChristophS wrote: Wed Apr 21, 2021 7:20 pm I installed that version. It didn't change that behavior.
Please add your full About info for each version of FreeCAD this occurs for you. Thanks.
Locked
