FreeCAD Website Design
Re: FreeCAD Website Design
It looks very good, but it increases the size by a factor of almost 10. We could have taken the original files from ppemawm then.
Of course i don't make it better... it is imposible to add information
I guess the software did not compress the image. I opened it in Gimp and exported it using the default .jpg format, the size reduced to around 400Kb. Even then the size is quite a lot especially if all images are considered together and this will slow the website. The original files from ppemawm would be the best solution. Still it's cool what A.I. based software can do now-a-days, especially with image editing.
resizing not that complicated... https://en.wikipedia.org/wiki/Image_scaling
It's way better!!! Can we use this one on the front page? The engine model is beautiful, but the quality of the image spoils the impression.AR795 wrote: ↑Wed Oct 17, 2018 6:33 am I came across this software called A.I. Gigapixel which does super-sampling of images, essentially converting a lower resolution image to a higher resolution one. I gave it a try on one of the images in the website to see how well it performs. Here is the image before super-sampling:
And here is after super-sampling:
The results are not perfect; in some areas details are lost or skewed but overall it does make the image sharper. So would it be fine to update the images using this technique or are existing images satisfactory?
I think the images can be upscaled without affecting size too much. I did a small test, where I converted all svg files to optimized svg, doubled the resolution of screenshots on the front page (except for the gear image) and used tinypng.com to optimize the file size of all images. So the total size of the images only increased by about ~150Kb altogether. I uploaded the changes on Github to see: https://ar795.github.io/FreeCAD-Homepage/
In my opinion this is great! I no longer have impression that there is something wrong with my eyes or the monitorAR795 wrote: ↑Wed Oct 17, 2018 8:19 pm I think the images can be upscaled without affecting size too much. I did a small test, where I converted all svg files to optimized svg, doubled the resolution of screenshots on the front page (except for the gear image) and used tinypng.com to optimize the file size of all images. So the total size of the images only increased by about ~150Kb altogether. I uploaded the changes on Github to see: https://ar795.github.io/FreeCAD-Homepage/
- kkremitzki
I think replacing the image is a great idea, I'm ready to do it whenever it's ready to be uploaded.
Yeah it makes quite a difference
Should I upload the images here or create a pull request?kkremitzki wrote: ↑Wed Oct 17, 2018 8:41 pm I think replacing the image is a great idea, I'm ready to do it whenever it's ready to be uploaded.
And a small question - In PHP, how do I add a ' character in a string? For example in:
<?php echo _('See what's new'); ?>
You can quote it or use double quotes - php can handle both:AR795 wrote: ↑Thu Oct 18, 2018 6:12 amgives me incorrect syntax highlighting, should I add a \ before the 'Code: Select all
<?php echo _("See what's new"); ?>
