ESC button in Sketch
Moderator: agryson
Jee-Bee
Re: ESC button in Sketch
Postby Jee-Bee » Sun Sep 02, 2018 2:27 pm
Weird from start menu didn't expect that one...
If it's not in the short cut menu it is probably hardcoded....
PaFe
Postby PaFe » Sun Sep 02, 2018 4:33 pm
So maybe it is possible to open a feature request to make this behaviour configurable by the user?
Postby chrisb » Sun Sep 02, 2018 4:45 pm
I have checked: I can assign a key, e.g. Cmd+Esc (Mac equivalent to Ctrl+Esc) to exit sketcher. But the Esc key alone leaves Sketcher as well. So a feature request would just remove the escape key. As PaFe has originally proposed.
Postby chrisb » Sun Sep 02, 2018 4:52 pm
Created ticket issue #3579.
PaFe
Postby PaFe » Sun Sep 02, 2018 6:17 pm
Great! Thank you so much
efyx
Postby efyx » Sun Sep 02, 2018 7:45 pm
I would like to use this opportunity and stand for use space or enter for recall last tool as in autocad it is. What do you think?
bejant
Postby bejant » Tue Sep 04, 2018 1:07 am
For all of FreeCAD, or only for Sketcher? Spacebar is already used to toggle visibility, and for Sketcher-only behavior I'd have to experiment with continuous mode a bit before offering an opinion...
Jee-Bee
Postby Jee-Bee » Tue Sep 04, 2018 5:07 am
Autocad is/was a keyboard prone software.
Most 3d cad are more mouse prone ... so if aso function excist I would expect and prefer it on the mouse button what I used for closing a function.
Postby chrisb » Tue Sep 04, 2018 6:31 am
Bejant mentioned continuous mode: without having selected any element click on one of the constraints, e.g. "vertical". Next you can click one by one all lines to be vertical.
efyx
Postby efyx » Tue Sep 04, 2018 7:57 am
Thanks for your voice. It is quite convincing, but still RMB has no good functionality. There should be "OK" and "Cancel" button obligatory to steer whole FreeCAD functions.
Continuous mode is really good, sketcher and especially Techdraw (where you need to select line and then dimension) should have it for sure.
