Glass
Moderator: agryson
triplus
Re: Glass
Postby triplus » Mon Nov 26, 2018 1:39 pm
NormandC wrote:
Sat Nov 24, 2018 9:34 pm
Is it something you think you can solve eventually, or is it a limitation of this widget overlaying method?
Glass module likely won't try to address this. Due to no straightforward way to achieve that. From pure tree view experience point of view. Yes this i guess is an issue. But then again if you actually do want to use the overlay approach, and eliminate the (side) dock widget approach, at minimum you need to use the tree view, properties view and tasks panel. Using just tree view won't work. As without all mentioned functionality, it is basically not possible to use FreeCAD ATM. Using any solution relying on this 3 widgets, and not resulting to hiding them in some way, will therefore likely result in some level of not being able to select geometry underneath it. There are and will be some mitigation solutions available in Glass module. For example pressing on Q+2 should already hide the overlay. There could i guess be the Q+3 option. Enabling the click through the overlay option. Being able to resize the overlay widget, will likely improve things in this area too.
Jee-Bee wrote:
Sat Nov 24, 2018 11:08 pm
Or an option to change the font colour of the model tree
I guess for start, finding a color that works good with defaults, makes the most sense.
Re: Glass
Postby Kunda1 » Mon Nov 26, 2018 2:07 pm
I wonder what feedback @ickby would give here now that @triplus has created the first steps to what may be the layout that ickby envisioned.
ickby wrote:
microelly2
Re: Glass
Postby microelly2 » Mon Nov 26, 2018 3:49 pm
Interesting.
Jee-Bee
Re: Glass
Postby Jee-Bee » Mon Nov 26, 2018 7:37 pm
I check at my mac and i see there is some space for improvement...
Screen Shot 2018-11-26 at 20.25.56.png (17.58 KiB) Viewed 330 times
few things. The view/ data tab show the different (default?) lines which is not what i like to see.
The fps counter (even if this is not important 99% of the time) is now stuck behind the tabs. So it would be better to move the fps counter to some place around.
If you have some ideas to similar result with the report view/ python console... The would be great.
OS: OS X El Capitan (10.11)
Version: 0.18.14976 (Git)
Branch: (HEAD detached at e79a19828)
Hash: e79a19828e2e92269ff96110dfeadaa245ad17c2
Python version: 2.7.15
Qt version: 5.11.2
OCC version: 7.2.0
Locale: English/Netherlands (en_NL)
Syres
Re: Glass
Postby Syres » Tue Nov 27, 2018 9:14 am
Thanks for the efforts @triplus, I'm happily using a simple Cyan background with the Glass WB and will be using multiple workbenches over the next couple of days to see if I can use this setup permanently.
OS: Windows 7
Version: 0.18.15215 (Git)
Hash: 54799368944d408a09fcdde41f89f20d282a9b8a
Python version: 3.6.6
Qt version: 5.6.2
triplus
Re: Glass
Postby triplus » Wed Nov 28, 2018 5:28 pm
Some default styling (stylesheet) will get applied in the future. This is not that much of an coding as it is a design related task.
Support for being able to resize the overlaying widget should be added in the future.
I haven't decided yet on how the "hiding" aspect will work. As if you overlay everything over the viewport, things quickly become counterproductive. But yes, overlaying arbitrary dock widget in the same way as Combo View. That should be supported in the future.
You're welcome. Note that pressing on Q+1 key combination can toggle the overlay widget mode back to the dock widget mode. If in some use case and situation that makes more sense.
Jee-Bee
Re: Glass
Postby Jee-Bee » Wed Nov 28, 2018 6:26 pm
Maybe more a core project... I would say time to think about a more space friendly environment...
Like it is now it let not much space... specially on a small screen.
The status bar for example is quite big ... Could this merged together with the tabs?
Also the widget bar(the bar what names the report view or the python console) is quit big Could this be hidden oid when not floating or moving around?
Something for later on separate topic i guess...
Screen Shot 2018-11-28 at 19.15.01.png (247.11 KiB) Viewed 232 times
triplus
Re: Glass
Postby triplus » Wed Nov 28, 2018 6:57 pm
Yes. In the future you should be able to use Glass module, and being able to show/hide arbitrary dock widget title bar.
P.S. If desired, without the need to overlay the dock widget.
Jee-Bee
Re: Glass
Postby Jee-Bee » Wed Nov 28, 2018 8:09 pm
thanks would be great!!
