Fits whole and Fits Selected Icons missing
Moderator: agryson
regis
Postby regis » Sun Feb 17, 2019 11:56 pm
has anyone noticed that these 2icons suddenly are missing? no matter how much I install resintall, no matter the version it doesn't show up. How to fix this?
Screenshot from 2019-02-17 18-52-08.png (14.15 KiB) Viewed 236 times
triplus
Re: Fits whole and Fits Selected Icons missing
Postby triplus » Mon Feb 18, 2019 12:04 am
Are you using a custom desktop icon theme? Does this fix it:
https://forum.freecadweb.org/viewtopic. ... 50#p286809
regis
Postby regis » Mon Feb 18, 2019 12:49 am
yes it it fixed it for the appimage which uses python3.6
but did not fix it for the daily ppa thich uses python 2.7
triplus
Postby triplus » Mon Feb 18, 2019 1:03 am
Are you sure the AppImage had the issue in the first place? If you revert to defaults:
p = FreeCAD.ParamGet("User parameter:BaseApp/Preferences/Bitmaps/Theme")
p.RemString("Name")
And re-start FreeCAD, AppImage has the issue? If yes, you are likely using a custom desktop icon theme? What happens if you revert that to defaults?
P.S. Note that FreeCAD must not crash on close, for the changes to have an effect. Only have one instance of FreeCAD running, when applying the changes and doing tests.
