COIL iconTheme
Moderator: agryson
1D_Inc
Re: COIL iconTheme
Postby 1D_Inc » Fri May 03, 2019 10:59 pm
Well, I made RCC (we will relase them later), but I didn't got how to enable them.
I reinstalled FreeCAD from 0.17 to 0.18, but only legacy Iconthemes addon takes effect.
Here is an example rcc
https://www.dropbox.com/s/20qd1vj7nh4r4 ... 1.rcc?dl=0
Sample QRC
<!DOCTYPE RCC><RCC version="1.0">
    <qresource prefix="/icons/COIL_LB_V01">
        <file>/mnt/D1A_1Tb/FCOIL/COIL_LB/index.theme</file>
    </qresource>
    <qresource prefix="/icons/COIL_LB_V01/scalable">
        <file>/mnt/D1A_1Tb/FCOIL/COIL_LB/COIL_LB_V01_SVG/Arch_Axis_Tree.svg</file>
  			<file>/mnt/D1A_1Tb/FCOIL/COIL_LB/COIL_LB_V01_SVG/Arch_BuildingPart.svg</file>
  			<file>/mnt/D1A_1Tb/FCOIL/COIL_LB/COIL_LB_V01_SVG/Arch_Panel_Sheet.svg</file>
  			<file>/mnt/D1A_1Tb/FCOIL/COIL_LB/COIL_LB_V01_SVG/Arch_Rebar_Tree.svg</file>
  			<file>/mnt/D1A_1Tb/FCOIL/COIL_LB/COIL_LB_V01_SVG/Arch_SplitMesh.svg</file>
  			<file>/mnt/D1A_1Tb/FCOIL/COIL_LB/COIL_LB_V01_SVG/web-zoom-in.svg</file>
    </qresource>
</RCC>
Sample index.theme
[Icon Theme]
Name=COIL LB V01
Comment=COIL LB V01 icon theme pack
Inherits=FreeCAD-default
Directories=scalable
[scalable]
Size=48
Type=Scalable
MinSize=1
MaxSize=256
triplus
Re: COIL iconTheme
Postby triplus » Fri May 03, 2019 11:37 pm
Well, I made RCC
Great!
Sample QRC
Sample index.theme
I don't have more time today, as for taking a quick look, the paths don't look good to me. Best if you start from here:
https://github.com/formjune/1D_SVG_Tools/pull/1
Or here:
https://github.com/triplus/1D_SVG_Tools/tree/Structure
Structure branch is used for the PR. Click on the Clone or download button and select Download ZIP option. After extracting the archive everything should already be in place for compiling. Point the rcc tool to qrc file(s) and test the resulting .rcc files after.
P.S. Fingers crossed!
1D_Inc
Re: COIL iconTheme
Postby 1D_Inc » Sat May 04, 2019 1:59 am
Aww, it was another branch with structure, qrc and icontheme files! It was painful, but I've got it.
Meanwhile, Iconslicer doesnot support structural slicing. Will know...
It seems, I still don't know how to launch them on windows.
There were no errors on compiling.
Also didn't got how to use them with linux Appimage.
Example of V02 rcc
https://www.dropbox.com/s/4ph5h8wa3x6cr ... 2.rcc?dl=0
No launch V02.png (72.39 KiB) Viewed 536 times
triplus
Re: COIL iconTheme
Postby triplus » Sat May 04, 2019 9:17 pm
Hi @1D_Inc
I will have more time for testing tomorrow or more likely the day after tomorrow.
1D_Inc
Re: COIL iconTheme
Postby 1D_Inc » Sat May 04, 2019 10:39 pm
Hi @1D_Inc
Okay. Thank you)
triplus
Re: COIL iconTheme
Postby triplus » Mon May 06, 2019 8:28 pm
Okay. Thank you)
I made some tests today and here are the results.
Example of V02 rcc
First congratulations as you were able to produce an icon pack in the .rcc format! Now on why you couldn't enable it on Windows and Linux. The problem is there are more versions of rcc format and on Arch Linux newer rcc tool is provided and it defaults to newer version of format. Older versions of Qt, like currently used in AppImage and likely in Windows binaries, don't have support for newer version of rcc format. But luckily newer versions of rcc tool can still compile/write in previous format version.
P.S. I updated instructions here and here.
1D_Inc
Re: COIL iconTheme
Postby 1D_Inc » Tue May 07, 2019 3:31 am
Thank you for clarification! I'll try to recompile them)
I've also spent this time to prepare release my Architectural Debris: Dust product. It took about half year.
I trained the modeling techniques and surface/shape/topology perception on it.
Can be interesting)
https://skfb.ly/6KpBW
1D_Inc
Re: COIL iconTheme
Postby 1D_Inc » Tue May 07, 2019 5:15 am
A very nice! RCC v03 is working)
Indeed, it was compiler version's issue)
Now I can check up almost entire interface in COIL theme.
Also, time to think about structural slicing.
We will place rcc files for test on github later, so Iet them be there for some time:
https://www.dropbox.com/s/wo0hsutk8glhx ... C.zip?dl=0
Yes, I noticed a visual color deprivation of blue themes, that's good, because it means that we have reached the limit we were aiming for.
I will figure out how to get around this.
I think about some red, despite its problems with the dark theme.
Also solid fills are used in every other software to fix shapes recognition deprivation, but I prefer to leave in an extreme case, maybe, for polishing, to avoid doubling the types of the SVG styles.
Color manipulations at the moment are cheaper for design workflow.
1D_Inc
Re: COIL iconTheme
Postby 1D_Inc » Wed May 08, 2019 7:51 pm
Tried 2.5px wire thickness instead 2.0
Small 16px icons became readable, but 32px looks too fatty.
Maybe, there is a reason to set thickness to something in between 2.0 and 2.5
Will think.
triplus
Re: COIL iconTheme
Postby triplus » Fri May 10, 2019 2:09 pm
Nice. Hopefully in the future with FCStd extension too! ;)
Good to hear that and i guess we have reached a milestone. Still some work left to do but now FreeCAD has a proper icon themes support and some high quality complementary icon theme packs that interested people can already start to use.
Will think.
Note that a possibility exist, to have a set of different SVG files in the same icon theme pack, used for different size (ranges).
That would be great.
