Per-project metrics
Moderator: agryson
adrianinsaval
Re: Per-project metrics
Postby adrianinsaval » Wed May 08, 2019 1:21 am
To offer my 2 cents, I'll sugest having the units as a property of the document and then have an easy to acces drop down menu or something of the sort allowing you to choose between using the document's units or metric, imperial, whatever and a 'custom' option that opens the preference panel about units.
traverseda
Postby traverseda » Sun Jun 30, 2019 10:24 pm
How about just changing the display? If I type 5ft 3 inches into a constraint, represent it internally in mm but leave the text as "5ft 3 inches".
Display mm on mouse over?
Unfortunately here in Canada we do end up having to mix units a lot, and it seems cleaner to me to make sure everything is displayed as what it actually is. 5 foot three inches might technically be 1600.2 mm, but that doesn't help if I'm converting a technical document from an imperial source.
