Squashed controls in Ubuntu 19.04
Moderator: agryson
Joel_graff
Postby Joel_graff » Tue May 28, 2019 10:55 am
So has this issue been identified?
Screenshot from 2019-05-28 05-53-00.png (14.04 KiB) Viewed 511 times
I noticed it several months ago when I was running Pop OS, and assumed it was just that distro, but apparently, it's ubuntu as well...
OS: Ubuntu 19.04
Version: 0.18.16117 (Git) AppImage
Branch: (HEAD detached at 0.18.2)
Hash: dbb4cc6415bac848a294f03b80f65e888d531742
Python version: 3.6.7
Qt version: 5.6.2
Site Admin
Re: Squashed controls in Ubuntu 19.04
Postby wmayer » Tue May 28, 2019 11:20 am
OS: Ubuntu 19.04
Qt version: 5.6.2
I wonder whether using this quite old Qt version on the latest Ubuntu version might be a problem. According to https://packages.ubuntu.com/search?keyw ... ection=all the used default version is 5.11.
Joel_graff
Postby Joel_graff » Tue May 28, 2019 11:50 am
That may be. I'm assuming I can't fix that without using a newer AppImage, right? If so, I'm out of luck, because I can't get 0.19 to run either as an AppImage or compile from source on my system. This appears my only option.
Site Admin
Postby wmayer » Tue May 28, 2019 12:08 pm
You can tmp. install the official FreeCAD from the Ubuntu repository. Even if this might be an old version you can at least easily test if the same dialog is broken or not.
Joel_graff
Postby Joel_graff » Tue May 28, 2019 1:03 pm
Right. I'll take a look at that later today and confirm. I've gotten so used to working with dev, I completely forget about the repo version :oops:
Also, while I've got your attention, I don't suppose you'd mind giving your opinion on this issue? (I suppose I'm hijacking my own thread ;) )
https://forum.freecadweb.org/viewtopic. ... 6&start=10
Site Admin
Postby wmayer » Tue May 28, 2019 1:53 pm
https://forum.freecadweb.org/viewtopic. ... 09#p310895
Joel_graff
Postby Joel_graff » Tue May 28, 2019 5:22 pm
The freecad 0.18 snap doesn't have that issue. Too bad it runs Python 2.7 :(
Joel_graff
Postby Joel_graff » Wed May 29, 2019 2:41 am
Ok, so I've learned the following about FreeCAD and my fresh install of Ubuntu 19.04
- v0.19 just doesn't work. It loads, but has (I'm guessing) a Py3 incompatibility issue. AppImage, FreeCAD-daily, and build from source all exhibit the same problem that prevents any workbench from loading. I've posted on this elsewhere...
- v0.18 AppImage works, but exhibits the squashed box issue
- v0.18 Snap works without issue. It's old. And ugly. But it works.
And with that, I have no other ideas.
Site Admin
Postby wmayer » Wed May 29, 2019 8:04 am
When looking at https://packages.ubuntu.com/search?keyw ... ection=all then apparently in 19.04 the FreeCAD package is not offered at all. eoan will this be the upcoming Ubuntu 19.10? There FreeCAD v0.18 is back.
vocx
Postby vocx » Wed May 29, 2019 5:24 pm
Yes, that seems to be the case. Kremitzki's response is basically that it was removed (due to some test error?) from 19.04. In order to include it again users would need to add the ubuntu-backports repository. So he thinks that if users need to activate an additional repository, they should forgo the backports, and just add the freecad-stable or freecad-daily repositories, and get the latest FreeCAD that way.
In 19.10 a version of FreeCAD 0.18 (0.18.2 or 0.18.3, if any is released) will be included as long as no error is found again.
kkremitzki wrote:
Thu May 09, 2019 1:42 am
... Regardless, it isn't going to be available because it was removed and 19.04 is already released; it might be possible to get it in via disco-backports but not disco proper, so someone obtaining it that way would have to add the -backports repo anyway; they might as well just add our PPA.
