[SOLVED] Request for IfcProject icon?
Moderator: agryson
Moult
Postby Moult » Sat Jun 15, 2019 10:27 pm
In the arch workbench, there is a new type of object called an IfcProject or IfcProjectLibrary. It allows you to define a "project" for the construction / architecture industry, and is part of the IFC OpenBIM industry standard. A project can contain a building site, which can then contain sub-sites, and sites can contain buildings (or facilities, which is the new proposal) and so on. A project library can contain types of objects which can be reused across projects, or groups of properties which are project requirements. A project can also contain a project library.
So basically, it's the top most element.
As an example below in the arch workbench, here is what a site, building, and building storey (i.e. floor of a building) icon looks like right now:
Relevant dev thread: https://forum.freecadweb.org/viewtopic. ... 73#p314673
bitacovir
Re: Request for IfcProject icon?
Postby bitacovir » Sun Jun 16, 2019 1:32 am
So. What is the concep that you guys want to use?
::bitacovir::
My personal web site
My old Blog
Mini Airflow Tunnel Project
Moult
Postby Moult » Sun Jun 16, 2019 2:00 am
I'm open to artistic interpretation! However I checked out the noun project and here are 5 results that communicate "project" to me in a construction context:
https://thenounproject.com/term/projects/1327109/
https://thenounproject.com/term/project/1281270/
https://thenounproject.com/term/project ... t/2034753/
https://thenounproject.com/term/project ... nt/995577/
bitacovir
Postby bitacovir » Sun Jun 16, 2019 2:48 am
Based on your first post, I understand the strongest feature of this ifcproject is to be a container.
So. What about a box?
ifc_project_icon2.svg
(9.22 KiB) Downloaded 25 times
::bitacovir::
My old Blog
Postby Kunda1 » Sun Jun 16, 2019 12:07 pm
Quick favor, I noticed in the previous SVG you most kindly created in a previous thread, that the SVG metadata needed to be updated as well. Here is the current metadata:
  <metadata
     id="metadata2985">
    <rdf:RDF>
      <cc:Work
         rdf:about="">
        <dc:format>image/svg+xml</dc:format>
        <dc:type
           rdf:resource="http://purl.org/dc/dcmitype/StillImage" />
        <dc:title />
        <dc:creator>
          <cc:Agent>
            <dc:title>[wmayer]</dc:title>
          </cc:Agent>
        </dc:creator>
        <dc:title>Part_Box</dc:title>
        <dc:date>2011-10-10</dc:date>
        <dc:relation>http://www.freecadweb.org/wiki/index.php?title=Artwork</dc:relation>
        <dc:publisher>
          <cc:Agent>
            <dc:title>FreeCAD</dc:title>
          </cc:Agent>
        </dc:publisher>
        <dc:identifier>FreeCAD/src/Mod/Part/Gui/Resources/icons/Part_Box.svg</dc:identifier>
        <dc:rights>
          <cc:Agent>
            <dc:title>FreeCAD LGPL2+</dc:title>
          </cc:Agent>
        </dc:rights>
        <cc:license>https://www.gnu.org/copyleft/lesser.html</cc:license>
        <dc:contributor>
          <cc:Agent>
            <dc:title>[agryson] Alexander Gryson</dc:title>
          </cc:Agent>
        </dc:contributor>
      </cc:Work>
    </rdf:RDF>
  </metadata>
bitacovir
Postby bitacovir » Sun Jun 16, 2019 1:53 pm
Ok. I changed the metadata.
ifc_project_iconMD.svg
(9.66 KiB) Downloaded 17 times
::bitacovir::
My old Blog
Moult
Postby Moult » Sun Jun 16, 2019 9:39 pm
Thanks bitacovir! Is it possible to have some symbology that suggests arch / engineering / construction project as well as the box? If you think that it will simply clutter too much, that's OK too.
I forgot to mention that apart from the yellow icon, there also needs to be a white icon to be used in the model tree, like in the screenshot below:
Do you mind creating that model tree icon too?
bitacovir
Postby bitacovir » Mon Jun 17, 2019 12:48 am
I can do the white icon. But first, you must choose... It is hard to think in a symbol with many meanings. And the real problem is the small icons, where the resolution of details is minimum.
I was thinking of a "top container" with strong Architectural/Engineering symbolism. I can only think of the basilica.
Other ideas that I considered.
A box with a ruler. Not too good for small icons.
Only the ruler. Mmmm maybe...
::bitacovir::
My old Blog
yorik
Site Admin
Postby yorik » Mon Jun 17, 2019 5:14 pm
I vote for the ruler or the brunelleschi dome :) Not enough arch symbols around here!
The ruler has the advantage that it conveys well the idea that the project (will) define a coordinates system.
bitacovir
Postby bitacovir » Mon Jun 17, 2019 6:28 pm
In the beginning, it was the white table. And the Architect put the T ruler on position, draw a line and he saw it was good.
::bitacovir::
My old Blog
