Visualisation problem
Hello everyone!
When I have two pieces in the same place and I try to select any of them, I have a problem with the visualisation of the selection. You'll probably see better in the picture. It's like a render problem.
How could I fix it?
Thanks
How could I fix it?
Thanks
Re: Visualisation problem
Hi and welcome to the forum!
There is nothing to be fixed, the effekt is known as z-fighting. If you want to make a single solid you could make Union of these two objects. But beware, usually it is not recommended to use booleans on coplanar faces.
I can't find the thread where one of the lead FreeCAD developers mentions this problem. It is known as Z-fighting, and it's not an easy to solve problem.
Z indicates the coordinate direction normal to the surface. So, it indicates that both surfaces fight to be on top. In your opinion, which surface should be on top? The two cubes are mathematically defined as having a face in exactly the same Z-coordinate, so how can you tell which should be on top? It's not as simple as saying this one or the other one.
- Joel_graff
It might be useful to address one case regarding z-fighting (which is nicely illustrated here). That is, where two faces are coplanar, the selected face should always be rendered on top.
I realize this can't be maintained in more complex selection cases (i.e., where multiple coplanar faces are picked), but if it's not a terribly difficult thing to implement in a single select case or a multi-select where no selected faces are coplanar, maybe we should put it on the list.
I'm not sure about this. For me it is a valuable information to see z-fighting, because it usually is something I don't want. It is either a visibility issue or I have modeled something unwanted. So z-fighting bears soome information in its own.Joel_graff wrote: ↑Tue Sep 17, 2019 11:40 amThat is, where two faces are coplanar, the selected face should always be rendered on top.
I agree. it is some kind of clash alert.
::bitacovir::
Canal Youtube Grupo Telegram de FreeCAD Español
My personal web site
My GitHub repository
Mini Airflow Tunnel Project
- Joel_graff
A good point.
Hello again!
Maybe we could create an optional z-fighting filter. Something like in the picture: In this case, you could conserve much information, but also you can disable the filter.
The criteria to render could be the actual selection or the creation order in the tree list.
Thanks for the answers
What's bad about seeing it? If it's about selecting one of the two faces it's a different issue, probably similar to selecting something which is not on top at all.
Well, I think it's a graphic design question (but I'm not graphic designer ). In the visualisation, you want to show the most relevant information in a graphic simple way. With the z-fighting effect you are using a lot of random graphic dynamic effects only to say that you have two o more things in the same position. But an easy graphic solution is to show only one static uniform effect (a color, a patron, etc) to show the same relevant information. I think it could be less distracting, more predictable, more easy to remember and understand, and in general, more efficient (graphically speaking ).
