Modern UI
- HakanSeven12
Re: Modern UI
Just click the arrow beside of the menu name
Support me: Hakan Seven on Patreon
Modern UI: Modern UI on FreeCAD Forum
Trails Workbench: Trails Workbench on FreeCAD Forum
Re: Modern UI
I am not sure if this is of any help, but I have occasionally had difficulty with losing menus etc in the past and think it might be related to trying my setup in both main stream Ver19 and realthunder's Link fork. Again not sure, but I think there is a different way in which the active WBs are recorded/used in user.cfg.
Sometimes it would take a couple of removals of ModernUI before it worked correctly, unfortunately as I haven't been able to reliably cause the error I haven't been very rigorous in recording my recovery routes.
Please ignore if you know more
Best wishes
Best wishes
- HakanSeven12
Re: Modern UI
Did you tried the newest version? I already made an update for that. Maybe you can try and report back if it's working or not.
Re: Modern UI
I did download, but it introduced another issue for my setup.HakanSeven12 wrote: ↑Fri Jan 08, 2021 10:20 am Did you tried the newest version? I already made an update for that. Maybe you can try and report back if it's working or not.
I assume your mod adding greyed out icons has meant that when editing
a sketch all the icons, except constraints, are inaccessible. I haven't had time to investigate
a work around so
to do work I have temporarily re-installed the Sketcher WB with no problems so far.
If you have any thoughts about accessing functions while in sketcher mode I would
be grateful
Best Wishes
- greyed_out_icons.png (105.18 KiB) Viewed 2802 times
- HakanSeven12
Re: Modern UI
İt's working for sketcher but not working for cadcam right? How can I create this cadcam tab?
- HakanSeven12
Re: Modern UI
This feature activated with last commitHakanSeven12 wrote: ↑Fri Jan 08, 2021 8:10 am I'm thinking about adding file and structure toolbars like this. They will always stay at icons only mode. What are you thinking about that?
https://www.patreon.com/posts/45954372
Re: Modern UI
Maalesef arabirim düzgün görüntülenmiyor.HakanSeven12 wrote: ↑Fri Jan 08, 2021 10:20 am Did you tried the newest version? I already made an update for that. Maybe you can try and report back if it's working or not.
Daha önce yükleyip kuualnmıştım.
Yanlış ya da eksik bir şey mi yaptım anlamadım.
Rapor görünümündeki hata mesajı;
21:32:31 Traceback (most recent call last):
21:32:31 File "/home/mhg/.FreeCAD/Mod/ModernUI/FCBinding.py", line 147, in selectWorkbench
21:32:31 self.createFileMenu()
21:32:31 File "/home/mhg/.FreeCAD/Mod/ModernUI/FCBinding.py", line 91, in createFileMenu
21:32:31 menu_list = workbench.listMenus()
21:32:31 File "<string>", line 70, in listMenus
21:32:31 AttributeError: 'PartDesignWorkbench' object has no attribute '__Workbench__'
21:32:31 File "/home/mhg/.FreeCAD/Mod/ModernUI/FCBinding.py", line 276, in __init__
21:32:31 QtCore.Qt.TopDockWidgetArea, MenuDock())
21:32:31 File "/home/mhg/.FreeCAD/Mod/ModernUI/FCBinding.py", line 46, in __init__
21:32:31 self.setWidget(ModernMenu())
21:32:31 File "/home/mhg/.FreeCAD/Mod/ModernUI/FCBinding.py", line 67, in __init__
21:32:31 self.selectWorkbench()
- q2.png (328.5 KiB) Viewed 2704 times
- HakanSeven12
Re: Modern UI
Partdesign ı bende kullanmıştım. Böyle bir sorun görmedim. Ancak pazartesi bakabilirim.
Re: Modern UI
Sven,HakanSeven12 wrote: ↑Fri Jan 08, 2021 6:43 am Its not a problem. I disabled them. If you want to see it go to FreeCAD/Mod/ModernUI folder and open FCBinding.py. At line 132, you will see this codeChange with thisCode: Select all
Defaults = ['File', 'Workbench', 'Macro', 'View', 'Structure']
Defaults = ['Workbench', 'Macro', 'View', 'Structure']
I did not see the ModernUI folder in Freecad/mod. Is that normal?
I think that the navigation of the UI like different views(top, bottom,..) as well as "Fit selection" should be readily available for the user. These are used very frequently. Also, I observed that hiding using the space bar is not working on my installation. I am using 0.19 from the folder instead of installing it.
Tussen Takk,
Vishy
- HakanSeven12
Re: Modern UI
If you are using widows, its under User/AppData/Roaming. But I already activated file and structure toolbars. So you need to update Modern UIvparmeshwar wrote: ↑Mon Jan 11, 2021 4:33 am I did not see the ModernUI folder in Freecad/mod. Is that normal?
You are right but I dınt want to add more toolbars until I implament dropdown menus.I think that the navigation of the UI like different views(top, bottom,..) as well as "Fit selection" should be readily available for the user. These are used very frequently.
Yeah most of shortcusts works but some of them are not working. I already open a thread about that. https://forum.freecadweb.org/viewtopic.php?f=22&t=54097Also, I observed that hiding using the space bar is not working on my installation. I am using 0.19 from the folder instead of installing it.
