Modern UI
hmk
Re: Modern UI
Post by hmk »
When running ModernUI and closing FreeCAD I get a segmentation fault. This does not happen when I run the same FreeCAD executable without ModernUI.
The log file ends with
Log: FreeCAD terminating...
Log: Saving system parameter...
Log: Saving system parameter...done
Log: Saving user parameter...
Log: Saving user parameter...done
so it seem this happens at the very end.
#0  /lib/x86_64-linux-gnu/libc.so.6(+0x3bd60) [0x7faf260ead60]
/tmp/.mount_freecan1cjZn/AppRun: line 41: 53374 Segmentation fault      ${MAIN} "$@"
[2]+  Exit 139
OS: PureOS (GNOME/gnome)
Version: 0.19.23964 (Git) AppImage
Hash: db9525e7d78c956df96dd6db2c52f20a50a2aa5f
Python version: 3.8.6
Qt version: 5.12.5
OCC version: 7.4.0
hmk
Re: Modern UI
Post by hmk »
HakanSeven12 wrote: Sat Feb 06, 2021 2:22 pm I can't solve the shortcuts issue. Same of the shortcuts are not working like del or space.
I also cannot use 1, 2, ...6, 0 for the views, which I use a lot. Is it possible to support these keys?
hmk
Running Modern UI in a self-contained directory
Post by hmk »
I just added the following to the Wiki: https://wiki.freecadweb.org/ModernUI_Workbench#Install
It may be of interest to uses that want to try out Modern UI in parallel to their existing setup. Version 0.19 required.
Screenshot_2021-02-19 ModernUI Workbench - FreeCAD Documentation.png (58.6 KiB) Viewed 5144 times
HakanSeven12
Re: Modern UI
Post by HakanSeven12 »
Hi there. I will take a look when I have time. Thanks for feedback.
MisterMaker
Re: Modern UI
Post by MisterMaker »
This addon is definitely my favorite addon!! Makes Freecad so more workable.
I had an issue with Modern UI with the collapsible docks not sticking. It just wouldn't stick.
Now this would not be a big issue if I could have disabled it without issues, but you need to restart Freecad when disabling it, which took me way to long to understand.
So 2 things:
Add a "Need restart" too the collapsible docks setting.
Put on to do list to fix it?
Original post:
https://forum.freecadweb.org/viewtopic.php?f=3&t=56034
Video about the issue:
https://twitter.com/MvdH74169613/status ... 2065648655
HakanSeven12
Re: Modern UI
I will fix that. Thanks for feedback.
MisterMaker
Re: Modern UI
Thanks for the fast reply.
I found another thing, but that is more the fault of missing toolbar in the mesh Design workbench. But I though I say it here since it took me a while until I found the hidden menu.
This is the tools
2021-03-01 12_37_45-FreeCAD 0.19.png (101.96 KiB) Viewed 4859 times
This is what you see in ModernUI:
2021-03-01 12_44_28-FreeCAD 0.19.png (37.21 KiB) Viewed 4859 times
Also one request if you got time for it. Is it possible to get these main menu icons to sit on top of the window.
2021-03-01 12_45_27-FreeCAD 0.19.png (69.8 KiB) Viewed 4859 times
It's a bit of a steal from Solidworks.
2021-03-01 12_47_26-SOLIDWORKS-2020-Screen-Section.jpg (JPEG-afbeelding, 1920 × 1080 pixels) - Gesch.png
2021-03-01 12_47_26-SOLIDWORKS-2020-Screen-Section.jpg (JPEG-afbeelding, 1920 × 1080 pixels) - Gesch.png (129.66 KiB) Viewed 4859 times
HakanSeven12
Re: Modern UI
You can access this menus under Modern UI tab when you activated mesh wb.
HakanSeven12
Re: Modern UI
Also I added menubar to fix shortcut issue. When I find another fix for it I will remove menubar again.
