Modern UI
Moderator: agryson
hwalseng
Re: Modern UI
Postby hwalseng » Tue Apr 07, 2020 12:39 pm
Great work HakanSeven12 :)
It's a really nice addition to the UI development.
Wishes from me:
  • A dialog, menu or setting where one can choose which workbenches that are shown
  • Possibility to enable autohide only for the bottom or side dialog
And a question:
How easy is it to rearrange the toolbars within the ribbon style workbenches?
I prefer to have the constraints on the right vertical side when working in sketcher, as an example.
Thank you for the work you've put into this so far :D
FreeCAD version info:
OS: Windows 10 (10.0)
Version: 0.19.20415 (Git)
Hash: 7a0606715045a255ef0774e835b0091eef300ac9
Python version: 3.8.2
Qt version: 5.12.5
OCC version: 7.4.0
Locale: Norwegian Bokmal/Norway (nb_NO)
HakanSeven12
Re: Modern UI
Postby HakanSeven12 » Tue Apr 07, 2020 12:49 pm
I will work for it when I have time
not as you want but a 'AH' button at the right bottom. It enable and disable autohide for all docks.
And a question:
If you click area above modern menu you can select toolbar you want.
bitacovir
Re: Modern UI
Postby bitacovir » Tue Apr 07, 2020 1:52 pm
HakanSeven12 wrote:
Mon Apr 06, 2020 2:27 pm
I need an icon for home tab. Anyone want to help?
Hi. I can help you. What idea do you have in mind?
::bitacovir::
My personal web site
My GitHub repository
My old Blog
Mini Airflow Tunnel Project
HakanSeven12
Re: Modern UI
Postby HakanSeven12 » Tue Apr 07, 2020 2:00 pm
Hi :) I wanted to add a home tab but I give up. Thank you
HakanSeven12
Re: Modern UI
Postby HakanSeven12 » Tue Apr 07, 2020 7:51 pm
I'm thinking about removing menus above the modern menu. I can add them to FreeCAD tab file menu. What do you think about that?
kisolre
Re: Modern UI
Postby kisolre » Tue Apr 07, 2020 7:52 pm
Tried for one session. Sketcher diameter/radius constraints can not be changed. Sorry if it was discussed before, did not read the whole thread...
HakanSeven12
Re: Modern UI
Postby HakanSeven12 » Tue Apr 07, 2020 7:59 pm
Create an issue at GitHub and make an explanation. You can add media too. I never used most of the workbenches.
HakanSeven12
Re: Modern UI
Postby HakanSeven12 » Wed Apr 08, 2020 8:13 am
I fixed it. I think all functions are available now.
dropdown menu.png (97.26 KiB) Viewed 133 times
dropdown menu2.png (139.83 KiB) Viewed 125 times
babaroga
Location: Banja Luka, Republic of Srpska, Bosnia and Herzegovina
Re: Modern UI
Postby babaroga » Wed Apr 08, 2020 8:50 am
Your UI looks really great. However, I get Segmentation fault on startup. Any Ideas?
This is what I get when I start it from terminal.
FreeCAD 0.19, Libs: 0.19R20477 (Git)
© Juergen Riegel, Werner Mayer, Yorik van Havre and others 2001-2020
FreeCAD is free and open-source software licensed under the terms of LGPL2+ license.
FreeCAD wouldn't be possible without FreeCAD community.
ModernUI is enabled
#0  /usr/lib/libc.so.6(+0x3bd70) [0x7f552ed18d70]
#1  0x7f552f210f46 in Shiboken::BindingManager::releaseWrapper(SbkObject*) from /usr/lib/libshiboken2.cpython-38-x86_64-linux-gnu.so.5.14+0x76
#2  /usr/lib/libshiboken2.cpython-38-x86_64-linux-gnu.so.5.14(+0x125e1) [0x7f552f2005e1]
#3  /usr/lib/libshiboken2.cpython-38-x86_64-linux-gnu.so.5.14(+0x12b35) [0x7f552f200b35]
#4  /usr/lib/libshiboken2.cpython-38-x86_64-linux-gnu.so.5.14(SbkDeallocQAppWrapper+0xa) [0x7f552f2018da]
#5  /usr/lib/libpython3.8.so.1.0(+0x128775) [0x7f55316cf775]
#6  /usr/lib/libpython3.8.so.1.0(+0x208a41) [0x7f55317afa41]
#7  /usr/lib/libpython3.8.so.1.0(PySet_New+0x4e4) [0x7f55316d0804]
#8  /usr/lib/libpython3.8.so.1.0(+0x1d813b) [0x7f553177f13b]
#9  /usr/lib/libpython3.8.so.1.0(+0x1d8f92) [0x7f553177ff92]
#10  /usr/lib/libpython3.8.so.1.0(PySymtable_BuildObject+0x194) [0x7f553180d464]
#11  /usr/lib/libpython3.8.so.1.0(PyAST_CompileObject+0x13d) [0x7f553181195d]
#12  /usr/lib/libpython3.8.so.1.0(Py_CompileStringObject+0x67) [0x7f5531813e37]
#13  /usr/lib/libpython3.8.so.1.0(+0x26d0c4) [0x7f55318140c4]
#14  /usr/lib/libpython3.8.so.1.0(+0x1422c2) [0x7f55316e92c2]
#15  /usr/lib/libpython3.8.so.1.0(PyVectorcall_Call+0x70) [0x7f55316e2ac0]
#16  /usr/lib/libpython3.8.so.1.0(_PyEval_EvalFrameDefault+0x58ba) [0x7f553179b38a]
#17  /usr/lib/libpython3.8.so.1.0(_PyEval_EvalCodeWithName+0x3d4) [0x7f5531785f34]
#18  /usr/lib/libpython3.8.so.1.0(_PyFunction_Vectorcall+0x39b) [0x7f55317872bb]
#19  /usr/lib/libpython3.8.so.1.0(_PyEval_EvalFrameDefault+0x11aa) [0x7f5531796c7a]
#20  /usr/lib/libpython3.8.so.1.0(_PyEval_EvalCodeWithName+0xc34) [0x7f5531786794]
#21  /usr/lib/libpython3.8.so.1.0(_PyFunction_Vectorcall+0x39b) [0x7f55317872bb]
#22  /usr/lib/libpython3.8.so.1.0(_PyEval_EvalFrameDefault+0x7de) [0x7f55317962ae]
#23  /usr/lib/libpython3.8.so.1.0(_PyFunction_Vectorcall+0x1bd) [0x7f55317870dd]
#24  /usr/lib/libpython3.8.so.1.0(_PyEval_EvalFrameDefault+0x7de) [0x7f55317962ae]
#25  /usr/lib/libpython3.8.so.1.0(_PyFunction_Vectorcall+0x1bd) [0x7f55317870dd]
#26  /usr/lib/libpython3.8.so.1.0(_PyEval_EvalFrameDefault+0x7de) [0x7f55317962ae]
#27  /usr/lib/libpython3.8.so.1.0(_PyFunction_Vectorcall+0x1bd) [0x7f55317870dd]
#28  /usr/lib/libpython3.8.so.1.0(_PyEval_EvalFrameDefault+0x39c) [0x7f5531795e6c]
#29  /usr/lib/libpython3.8.so.1.0(_PyFunction_Vectorcall+0x1bd) [0x7f55317870dd]
#30  /usr/lib/libpython3.8.so.1.0(_PyEval_EvalFrameDefault+0x39c) [0x7f5531795e6c]
#31  /usr/lib/libpython3.8.so.1.0(_PyFunction_Vectorcall+0x1bd) [0x7f55317870dd]
#32  /usr/lib/libpython3.8.so.1.0(+0x156dc8) [0x7f55316fddc8]
#33  /usr/lib/libpython3.8.so.1.0(_PyObject_CallMethodIdObjArgs+0x24d) [0x7f5531765f3d]
#34  /usr/lib/libpython3.8.so.1.0(PyImport_ImportModuleLevelObject+0xb0d) [0x7f55316cd66d]
#35  /usr/lib/libpython3.8.so.1.0(_PyEval_EvalFrameDefault+0x4557) [0x7f553179a027]
#36  /usr/lib/libpython3.8.so.1.0(_PyFunction_Vectorcall+0x1bd) [0x7f55317870dd]
#37  /usr/lib/libpython3.8.so.1.0(PyObject_Call+0x1ed) [0x7f55316e2f2d]
#38  0x7f552f249c4b in PySide::SignalManager::callPythonMetaMethod(QMetaMethod const&, void**, _object*, bool) from /usr/lib/libpyside2.cpython-38-x86_64-linux-gnu.so.5.14+0x9b
#39  /usr/lib/libpyside2.cpython-38-x86_64-linux-gnu.so.5.14(+0x14229) [0x7f552f24e229]
#40  /usr/lib/libQt5Core.so.5(+0x2db252) [0x7f552f7ec252]
#41  0x7f5532d6e255 in Gui::MainWindow::workbenchActivated(QString const&) from /home/senja/freecad-build/lib/libFreeCADGui.so+0x35
#42  0x7f5532d6ed7e in Gui::MainWindow::activateWorkbench(QString const&) from /home/senja/freecad-build/lib/libFreeCADGui.so+0xde
#43  0x7f55329405e2 in Gui::Application::activateWorkbench(char const*) from /home/senja/freecad-build/lib/libFreeCADGui.so+0xbd2
#44  0x7f55329428c0 in Gui::Application::runApplication() from /home/senja/freecad-build/lib/libFreeCADGui.so+0x10b0
#45  ./FreeCAD(main+0x710) [0x55a0b30b18f0]
#46  /usr/lib/libc.so.6(__libc_start_main+0xf3) [0x7f552ed04023]
#47  ./FreeCAD(_start+0x2e) [0x55a0b30b1bfe]
My FC was built this morning from master:
OS: Manjaro Linux (KDE//usr/share/xsessions/plasma)
Version: 0.19.20477 (Git)
Hash: 7d8ab175a68e476427e6e337fe3099b52da49dc8
Qt version: 5.14.1
OCC version: 7.4.0
HakanSeven12
Re: Modern UI
Postby HakanSeven12 » Wed Apr 08, 2020 8:58 am
I don't recommend daily ppa for this mod. It some times couse crashes. You can try appimage version from github.
My system info:
Qt version: 5.12.5
OCC version: 7.4.0
Locale: Turkish/Turkey (tr_TR)
