New overlay mode (Now ready for testing)
Moderator: agryson
realthunder
Re: New overlay mode (soon ready for testing)
Postby realthunder » Fri Apr 24, 2020 12:48 pm
Pauvres_honteux wrote:
Fri Apr 24, 2020 8:48 am
I've focused the eye of Argus on it !
Regarding the App-Image, any chance of getting your work on "multi-body" included in it as well?
I just made the release. Welcome to try. Multi-body is not ready yet. Please check the release notes for changes.
carlopav
Re: New overlay mode (Now ready for testing)
Postby carlopav » Fri Apr 24, 2020 6:03 pm
tried it and... it's just super cool to have the transparent TreeView! thanks for your hard work!
bitacovir
Postby bitacovir » Fri Apr 24, 2020 7:57 pm
I tried it and it is awesome!!
::bitacovir::
My personal web site
My GitHub repository
My old Blog
Mini Airflow Tunnel Project
pablogil
Postby pablogil » Sat Apr 25, 2020 7:30 am
Really nice work!! Congrats!
I think it's the best overlay mode approach I have seen so far.
Just to learn more about it:
  • is would be possible to pack it as an addon in order to use it with regular FreeCAD?
  • is it possible to style it with .qss stylesheets?
Cheers
nic
Postby nic » Sat Apr 25, 2020 8:41 am
Wow!
I'm specially amazed by this tab. Is this part of the new features? Was it existing and hidden before?
This solves a long annoying stuff for me : on really big sub-nested models,I never found a way to show all "parts" once you played with several show visibility toggle. Showing everything shows all the planes and axis which is a pain to reset to no-visibility.
Wit this new feature, I can:
* show everything as before (this show planes and axis as well)
* search by name for 'Origin', select a random item in the list found, and a single "space key" hit will toggle off all the planes and axis
[edit] 15 minutes I play with this new panel, and I cannot do without it! @realthunder I'm stuck with your appimage branch now!
Congrats!
nic
Postby nic » Sat Apr 25, 2020 9:03 am
By the way, a great new feature (at least for me) would be to be able to "group" all found objects into a draft layers. This would allow to, let say, search all brackets, or screws, and maye a layer of them. This way, it would be easy to toggle visibility for any groups of objects...
Pauvres_honteux
Postby Pauvres_honteux » Sat Apr 25, 2020 10:16 am
Things really do shine in this fork of yours @realthunder!
While in Part Design and trying to create a datum-, point, line or plane I got instant crash without any message of any sort.
Though I did notice some complaints while starting FreeCAD:
Start of FreeCAD ASM3 20200424 yelded:
Report view:
During initialization the error "/bin/sh: /tmp/.mount_FreeCAlNmtbm/usr/lib/libtinfo.so.6: no version information available (required by /lib64/libreadline.so.7)
" occurred in freecad.pip
  File "<string>", line 150, in InitApplications
  File "/tmp/.mount_FreeCAlNmtbm/usr/lib/python3.7/importlib/__init__.py", line 127, in import_module
    return _bootstrap._gcd_import(name[level:], package, level)
  File "<frozen importlib._bootstrap>", line 1006, in _gcd_import
  File "<frozen importlib._bootstrap>", line 983, in _find_and_load
  File "<frozen importlib._bootstrap>", line 967, in _find_and_load_unlocked
  File "<frozen importlib._bootstrap>", line 677, in _load_unlocked
  File "<frozen importlib._bootstrap_external>", line 728, in exec_module
  File "<frozen importlib._bootstrap>", line 219, in _call_with_frames_removed
  File "/tmp/.mount_FreeCAlNmtbm/usr/lib/python3.7/site-packages/freecad/pip/init_gui.py", line 12, in <module>
    from freecad.pip.gui import PipWidget
  File "/tmp/.mount_FreeCAlNmtbm/usr/lib/python3.7/site-packages/freecad/pip/gui.py", line 3, in <module>
    from freecad.pip.app import pip
  File "/tmp/.mount_FreeCAlNmtbm/usr/lib/python3.7/site-packages/freecad/pip/app.py", line 115, in <module>
    pip = _pip()
  File "/tmp/.mount_FreeCAlNmtbm/usr/lib/python3.7/site-packages/freecad/pip/app.py", line 30, in __init__
    self.freeze()
  File "/tmp/.mount_FreeCAlNmtbm/usr/lib/python3.7/site-packages/freecad/pip/app.py", line 97, in freeze
    for pkg_name, version in self.list_system():
  File "/tmp/.mount_FreeCAlNmtbm/usr/lib/python3.7/site-packages/freecad/pip/app.py", line 89, in list_system
    non_system = self.list_user_and_editable()
  File "/tmp/.mount_FreeCAlNmtbm/usr/lib/python3.7/site-packages/freecad/pip/app.py", line 67, in list_user_and_editable
    packages = process("pip", "list", "--user")
  File "/tmp/.mount_FreeCAlNmtbm/usr/lib/python3.7/site-packages/freecad/pip/app.py", line 24, in process
    raise RuntimeError(err.decode("utf8"))
RuntimeError: /bin/sh: /tmp/.mount_FreeCAlNmtbm/usr/lib/libtinfo.so.6: no version information available (required by /lib64/libreadline.so.7)
Python console
Python 3.7.6 | packaged by conda-forge | (default, Mar 23 2020, 23:07:43)
[GCC 7.3.0] on linux
Type 'help', 'copyright', 'credits' or 'license' for more information.
>>> Gui.runCommand('Std_ViewStatusBar',1)
>>> Gui.runCommand('Std_ViewStatusBar',0)
>>> Gui.runCommand('Std_Workbench',22)
>>> Gui.runCommand('Std_DockOverlayAll',0)
realthunder
Postby realthunder » Sat Apr 25, 2020 11:50 am
I think it is possible to translate most of the functionality to PySide code, most of which are implemented in src/Gui/DocWindowManager.h/cpp
[*]is it possible to style it with .qss stylesheets?[/list]
Yes, please check the opening post for instructions. I have also made some minor change on the existing stylesheet, e.g. here.
nic
Postby nic » Sat Apr 25, 2020 11:55 am
same issue here
OS: Ubuntu 19.10 (GNOME-Flashback:GNOME/regolith)
Version: 0.19.20545 +2163 (Git) AppImage
Branch: LinkStage3
Hash: 0fbd40c9b29ead11d716d3178fa7036173ed6592
Python version: 3.7.6
Qt version: 5.12.1
Coin version: 4.0.0
OCC version: 7.4.0
Locale: French/France (fr_FR)
realthunder
Postby realthunder » Sat Apr 25, 2020 1:31 pm
same issue here
Image updated. Please check.
