New overlay mode (Now ready for testing)
adrianinsaval
Re: New overlay mode (Now ready for testing)
Post by adrianinsaval »
bambuko wrote: Tue Jan 18, 2022 4:20 pm
adrianinsaval wrote: Tue Jan 18, 2022 4:13 pm...Do you have the same panels enabled ...
Yes, I always use the same panels (bit OCD :mrgreen: )
enabled =/= visible, at least in master branch there are various panels that are not available unless you set parameters to enable them, then you can make them visible from that context menu. Compare the context menu on your clean config and your vert ui config and see if there's a difference in the panels available. Also one could have the combo view option while in another you have tree view, property view and task view separated.
Actually, no need to, I've just checked myself first with a clean config:
then after importing vertical UI config:
There is no bug, you just have a different config with a different set of panels available.
Post by Kunda1 »
Kunda1 wrote: Mon Jan 17, 2022 4:11 pm Question: Is there a way to make the overlay aware of the the color behind it and have it dynamically adjust itself to compensate?
ref: https://github.com/StudioPetrikas/FreeC ... I/issues/3
Note: VertUI is experimental.
Rebumping this issue to the end of this thread so it doesn't get lost
