I
think I found a bug....
How it should be:
- ProjectionSuccess.jpeg (263.52 KiB) Viewed 3637 times
This is how it becomes after the recompute prompt when opened with LinkStage3 branch:
- ColorBug.jpeg (180.33 KiB) Viewed 3637 times
Some observations:
-in previous iterations of this file I've seen similar "residual" geometry when using a PartDesign boolean between the flag pole body and the "Projection Object". Unfortunately I haven't saved the file at that stage.
- this started happening only after I changed the colors of the "Part" and "projection object" . Prior to that the file opened and recomputed correctly.
-this is one way that I can reproduce the bug (by opening a file saved with FC master) but it can be reproduced directly in LinkStage3 by:
1-chose "set colors" on a feature in the tree
2-select a face
3-click edit and chose a color
4-result: geometry messed up
Also, what is the policy for some PR from master to be cherry piked to be included in your build? I'm interested in this atm:
https://github.com/FreeCAD/FreeCAD/pull/3796 as it is directly related to this model. But it is good to know how sinking with master works in the LnkStage3 branch case.
Thank you and best regards.
