Ok. I decided to change some colors for a better contrast for small icon versions. This is the first group of icons. Tomorrow, I'll submit the rest of them.
[Help]Icons for Trails Workbench
Re: [Help]Icons for Trails Workbench
::bitacovir::
Canal Youtube Grupo Telegram de FreeCAD Español
My personal web site
My GitHub repository
Mini Airflow Tunnel Project
- HakanSeven12
Thanks for help
Support me: Hakan Seven on Patreon
Modern UI: Modern UI on FreeCAD Forum
Trails Workbench: Trails Workbench on FreeCAD Forum
Those look great. I'm really excited to see this workbench moving forward. Bitacovir I would love to see a video if your process working in inkscape!
I often am concerned with color blind readability when using red and green but in this case it seems there is enough clarity in the iconography cues to overcome it.
- HakanSeven12
After using a little, you don't need to search for icon which you want to click. Because you memorize it position. So I don't think color blindness is a problem for green icons.
I agreeHakanSeven12 wrote: ↑Thu May 28, 2020 10:22 pm After using a little, you don't need to search for icon which you want to click. Because you memorize it position. So I don't think color blindness is a problem for green icons.
- eccioloste
I am colorblind, "we" always find our way of understanding icons regardless of the color. But, don't create two icons that are exactly the same with different color only, that would be confusing. If you haven't got any other way, avoid using green and red in that case.
Thanks!
Icons look great!
Thanks!
Icons look great!
Can you tell me what represent these icons?
Ok. From now on, I will keep that in mind.eccioloste wrote: ↑Fri May 29, 2020 7:10 am I am colorblind, "we" always find our way of understanding icons regardless of the color. But, don't create two icons that are exactly the same with different color only, that would be confusing. If you haven't got any other way, avoid using green and red in that case.
::bitacovir::
- HakanSeven12
Create sections from mesh
Edit highway centerline
Import point file
Create lines that orthogonal to centerline
Import point file
Here, the final group of icons.
::bitacovir::
- HakanSeven12
Looks good my mesh is not like a box. It represent the earth surface. Here an example
- surf.png (119.51 KiB) Viewed 2810 times
- sec.png (125.25 KiB) Viewed 2811 times
- 59920075-fff40000-9431-11e9-8411-b13032364f28.gif (876.41 KiB) Viewed 2816 times
