[Merged] Icons for Mesh Design WB
bitacovir
Post by bitacovir »
Thanks of this post, I just notice Mesh Design WB lacks of some icons: https://forum.freecadweb.org/viewtopic.php?f=8&t=47493
I thought to open this thread to make some design proposals, and then, people can give some feedback if some of them are not good enough.
Please, let me know if this is not pertinent.
Link to the wiki workbench: https://wiki.freecadweb.org/Mesh_Workbench
link to the Artwork wiki: https://wiki.freecadweb.org/Artwork_Mesh
::bitacovir::
Canal Youtube Grupo Telegram de FreeCAD Español
My personal web site
My GitHub repository
Mini Airflow Tunnel Project
saso
Re: Icons for Mesh Design WB
Post by saso »
+1 :)
bitacovir
Post by bitacovir »
Mesh FillHoles Tool https://wiki.freecadweb.org/Mesh_FillHoles
Mesh_FillHoles.svg
(6.73 KiB) Downloaded 78 times
Mesh AddTriangle Tool https://wiki.freecadweb.org/Mesh_AddTriangle
Mesh_AddTriangle.svg
(8.44 KiB) Downloaded 83 times
::bitacovir::
bitacovir
Post by bitacovir »
Mesh RemoveCompByHand Tool https://wiki.freecadweb.org/Mesh_RemoveCompByHand
Mesh_RemoveCompByHand.svg
(10.36 KiB) Downloaded 76 times
::bitacovir::
bitacovir
Post by bitacovir »
Mesh Scale Tool https://wiki.freecadweb.org/Mesh_Scale
Mesh_Scale.svg
(12.78 KiB) Downloaded 75 times
::bitacovir::
vocx
Post by vocx »
bitacovir wrote: Thu Jun 11, 2020 2:08 am Thanks of this post, I just notice Mesh Design WB lacks of some icons: https://forum.freecadweb.org/viewtopic.php?f=8&t=47493
Where did you notice this? In the actual program or only in the wiki? Information in the wiki often is obsolete, so to confirm that there are commands without icon you must consult the source code.
bitacovir
Post by bitacovir »
vocx wrote: Sat Jun 13, 2020 11:58 am Where did you notice this? In the actual program or only in the wiki? Information in the wiki often is obsolete, so to confirm that there are commands without icon you must consult the source code.
Saso mentioned in his post and then, I saw many commands in the Meshes menu, in the actual program, without icons. I know the wiki is not always updated. So, I am checking in the menu what command don't have icon, because I don't know how to check and read the source code. Could be possible that there are more mesh icons when they are not displayed in the meshes menu?
::bitacovir::
bitacovir
Post by bitacovir »
Mesh Union Tool https://wiki.freecadweb.org/Mesh_Union
Mesh_Fuse.svg
(13.95 KiB) Downloaded 65 times
Mesh Intersection Tool https://wiki.freecadweb.org/Mesh_Intersection
Mesh_Common.svg
(10.65 KiB) Downloaded 75 times
Mesh Difference Tool https://wiki.freecadweb.org/Mesh_Difference
Mesh_Difference2.svg
(11.9 KiB) Downloaded 80 times
::bitacovir::
HakanSeven12
Post by HakanSeven12 »
Nice icons
bitacovir
Post by bitacovir »
Mesh EvaluateRepair Tool https://wiki.freecadweb.org/Mesh_EvaluateRepair
Mesh_EvaluateRepair.svg
(15.51 KiB) Downloaded 83 times
::bitacovir::
