Custom cursors and high dpi (Windows and MacOS testers needed)
Moderator: agryson
vocx
Re: Custom cursors and high dpi (Windows and MacOS testers needed)
Postby vocx » Fri Aug 07, 2020 2:40 pm
vanuan wrote:
Sun Aug 02, 2020 4:31 am
...This PR is getting larger and larger. I'm afraid it's getting harder to review. Would you suggest I create a separate PR or continue improvements in this one?...
I do suggest you keep the pull requests small, with less than 10 commits each, if possible. And I would also avoid touching a lot of files at the same time, although this is unavoidable some times.
There is no way to speed up review and merging. Maybe if you bribe with millions of dollars one of the people with merge privileges you can expedite this. But otherwise, that's just how it is. Contribute as much as possible. It won't be a waste, you just need to be patient.
