[FIXED] Ticket #4493 - InsertDatum.ui dialog height too small
Founder
Re: InsertDatum.ui dialog height too small
Post by wmayer »
dennisb wrote: Sun Nov 15, 2020 9:19 am It would be nice if someone on Mac/Windows could test without the <property name="minimumSize"> node in InsertDatum.ui so we can see if it still work in other os:es.
Nice finding! It looks it's a regression caused by git commit 2d9c2c64. I will remove the minimum size hint from the UI file and test how it behaves on Linux and Windows. If it is OK I will commit the changes.
Thank you very much!
Founder
Post by wmayer »
Post by Kunda1 »
Awesome!
OP please mark this thread [FIXED] by editing the first post title summary.
Thanks to all involved!
dennisb
Re: [FIXED] InsertDatum.ui dialog height too small
Post by dennisb »
Before starting this thread I made the mistake of opening issue #4493 but it doesn't look like I have permission to close it again.
Thanks for the help fixing this. I still don't know why there is a dialog height of 140 set in the ui file. It doesn't hurt and maybe it helps someone on some OS but it can probably also be removed.
Re: [FIXED] Ticket #4493 - InsertDatum.ui dialog height too small
Post by Kunda1 »
Closed issue #4493
Thank you.
Founder
Post by wmayer »
dennisb wrote: Sun Nov 15, 2020 12:49 pm Thanks for the help fixing this. I still don't know why there is a dialog height of 140 set in the ui file. It doesn't hurt and maybe it helps someone on some OS but it can probably also be removed.
For each UI file a width and height is set. You cannot remove that. Since a dialog must have a layout the defined size doesn't matter because the dialog will expand if necessary.
Dr_Pi
Post by Dr_Pi »
I still get this issue in 0.19.
OS: Linux Mint 20.1 (X-Cinnamon/cinnamon)
Version: 0.19.
Branch: unknown
Hash: 0d9536ed3e8c7f40197b5606e1b7873625e1d6fe
Python version: 3.8.10
Qt version: 5.12.8
OCC version: 7.5.2
Dr_Pi wrote: Wed Jul 28, 2021 6:40 am I still get this issue in 0.19.
You can try to reset the configuration with the button in the preferences. Another possibility is to delete your config files or to move them in case you want to restore them.
Syres
Post by Syres »
I don't know where you got that version of 0.19 (it looks like an old PPA) but the correct hash for 0.19.2 is 7b5e18a0759de778b74d3a5c17eba9cb815035ac as shown in the Windows build below. I might not be searching the commits correctly but I can't even find your quoted commit in the FreeCAD master list.
OS: Windows 7 Version 6.1 (Build 7601: SP 1)
Version: 0.19.24291 (Git)
Branch: releases/FreeCAD-0-19
Python version: 3.8.6+
Qt version: 5.15.2
Coin version: 4.0.1
OCC version: 7.5.0
