Touch screen multi selection
Re: Touch screen multi selection
This is cool! I'm not qualified to review this but it i didn't take much code to achieve the PoC.
Care to weigh in ?DeepSOIC wrote: pinged by pinger macro
edit: see https://forum.freecadweb.org/viewtopic. ... 65#p463371
- DeepSOIC
looks good to me, sorry i can't test now.
I'm not very interested in this feature personally, because i don't like detachable keyboards, but i like this small change.
After finishing up the PR, I tested it for about half an hour and I haven’t been able to get check selections and check marks out of sync.
The only odd behavior I found during testing was that you can drag select over several checkboxes to quickly select multiple items. After one is selected it will try to drag-n-drop them instead (I think it works because the drag event is initiated before the object is selected, hence nothing can be dragged).
However, I think this is an unintended feature rather than a bug
PR can be accessed here: https://github.com/FreeCAD/FreeCAD/pull/4250
this is what we need . I have seen somewhere added "eye" to turn on/off visibility as well.
its not the problem with typing numbers because in surface is popping out but ctrl require to change keyboard type then press permanent ctrl.
I don't know how about the other tablets . I reckon that small virtual numeric keyboard popping out when value cell is beeing chosen would be awesome for touchscreen users.
I don't know how to compile and use your code but regarding your video I can say spot on!
regard
regard
Kundalini....
