And I sir.... am upvoting YOUR upvote!
New ProDark Theme with 4k small text Mod
Re: New ProDark Theme with 4k small text Mod
Will do..If i knew how
1. Go to https://github.com/FreeCAD/FreeCAD/comp ... eeCAD-0-18
2. Create PR button
3. Delete how to info
4. Write info and attach file
5. Where do i say FreeCAD/src/Gui/Stylesheets/
6. This could all be wrong
Nice try. You want the PR against master branch not FreeCAD-0-18turn211 wrote: ↑Mon Feb 15, 2021 6:10 pm Will do..If i knew how
2. Create PR button
This is documented in https://wiki.freecadweb.org/Source_code ... rk_locally
In your browser go to https://github.com/FreeCAD/FreeCAD
Press the fork button
You should have a fork called https://github.com/turn211/FreeCAD
In the command line terminal:
git clone https://github.com/turn211/FreeCAD
git remote add upstream https://github.com/FreeCAD/FreeCAD
git checkout master
git branch ProDark-Theme
git checkout ProDark-Theme
git add .
git commit -m "Gui: Add new stylesheet ProDark theme" -m "forum thread: https://forum.freecadweb.org/viewtopic.php?f=34&t=55134"
git push origin ProDark-Theme
Go to https://github.com/turn211/FreeCAD
You'll see a link at the top of the page asking if you want to compare and make a PR. Click it.
The details of the PR should be in there. If not then copypaste them in.
Press Make Pull Request.
The way to do that is with git commit --amend
If you want to learn git in a great way check out this thread: https://forum.freecadweb.org/viewtopic.php?f=8&t=51557
You want to close the PR and try again, this time making your own branch off of master?
I closed the PR. I'm going to delete turn211/FreeCAD repository also and start again. Clean slate Ok?
Not necessary to delete the whole repo.
Are you purely working on Github or are you working on you computer locally and then pushing to github ?
Home for Lunch. PR completed. Thanks
