New ProDark Theme with 4k small text Mod
Re: New ProDark Theme with 4k small text Mod
Post by Kunda1 »
Note: Best way to test this it's good to make sure one is using the most up to date version of the ProDark stylesheet.
1. open a terminal
2. cd ~/.FreeCAD/Gui/Stylesheet || mkdir ~/.FreeCAD/Gui/Stylesheet && cd ~/.FreeCAD/Gui/Stylesheet
If you don't have the prodark theme installed locally then
3. git clone https://github.com/turn211/ProDark-FreeCAD-theme/
If ProDark is already installed locally:
4. git pull
5. Restart FreeCAD
turn211
Post by turn211 »
bitacovir wrote: Tue Mar 16, 2021 2:31 pm The Image Scaling window (Image Workbench) does not have the text in ProDark Theme.
Thanks for trying the theme out. I can see by the colour of the WorkBench background you are using an old copy of ProDark theme. I even tried your version on my 3 machines and it works as should. I can also see by the picture of the no stylesheet that your FreeCAD needs to be restarted. When changing themes it is good practise to pick your theme then restart FreeCAD. Try downloading the latest version and see if it works for you. If you see a Blue WorkBench you are on a later version. Cheers.
bitacovir
Post by bitacovir »
turn211 wrote: Tue Mar 16, 2021 10:34 pm Thanks for trying the theme out. I can see by the colour of the WorkBench background you are using an old copy of ProDark theme. I even tried your version on my 3 machines and it works as should.
Yes. I was using the ProDark Theme installed as default in FC 0.19.24267
I downloaded and installed it from your github repo and now works fine. Thanks.
::bitacovir::
Canal Youtube Grupo Telegram de FreeCAD Español
My personal web site
My GitHub repository
Mini Airflow Tunnel Project
turn211
Post by turn211 »
bitacovir wrote: Wed Mar 17, 2021 2:38 pm Yes. I was using the ProDark Theme installed as default in FC 0.19.24267
Glad it's working or maybe not. Curious are you having the same issue as i am https://forum.freecadweb.org/viewtopic.php?f=34&t=56875 in the latest 0.19 Release. If so it's a regression and i can't fix it. I think the build is not using QWindowsStyle on the Property tabs or something close to that.
QWindowsStyle not applied to ComboView Property Tabs.png (7.3 KiB) Viewed 3643 times
bitacovir
Post by bitacovir »
turn211 wrote: Mon Mar 22, 2021 9:16 pm
Glad it's working or maybe not. Curious are you having the same issue as i am https://forum.freecadweb.org/viewtopic.php?f=34&t=56875 in the latest 0.19 Release. If so it's a regression and i can't fix it. I think the build is not using QWindowsStyle on the Property tabs or something close to that.QWindowsStyle not applied to ComboView Property Tabs.png
I don't remember that problem. Now I am using in FC0.19 last version of ProDark downloaded from your repo. Also, I have FreeCAD 0.20.
OS: Windows 10 (10.0)
Version: 0.19.24267 (Git)
Hash: b2ca86d8d72b636011a73394bf9bcdedb3b109b7
Python version: 3.8.8
Qt version: 5.12.5
OCC version: 7.4.0
OS: Windows 10 Version 1909
Version: 0.20.24451 (Git)
Hash: 9c8685c20cd70553d85940c2ba93ade69f38171d
Python version: 3.8.6+
Qt version: 5.15.1
Coin version: 4.0.1
OCC version: 7.5.0
::bitacovir::
turn211
Post by turn211 »
bitacovir wrote: Tue Mar 23, 2021 12:02 pm I don't remember that problem. Now I am using in FC0.19 last version of ProDark downloaded from your repo. Also, I have FreeCAD 0.20
Thanks for posting. I see the bottom tabs are not getting styled square in all builds after Version 0.19.24267 on Windows. This a regression that i can't fix so I'll have to make a PR on Tracker.
turn211
Post by turn211 »
turn211 wrote: Tue Mar 23, 2021 3:32 pm
Fixed in PR 4668
Eneen
Post by Eneen »
Hi!
Using build-in ProDark in FC 0.19.3 on 4k display. Is it possible to adjust toolbar/panel/status bar padding? It's ok without any stylesheet, take a look:
turn211
Post by turn211 »
Eneen wrote: Wed Dec 29, 2021 12:56 pm Hi!
I don't know what os you are using but it is possible. Tightening the padding breaks a lot of other elements. Until i have some free time i can't do all the bug testing required make this request possible. Thanks
Eneen
Post by Eneen »
Ah, sorry, Windows 11.
Ok, thx a lot!
