UI Improvements / Vertical UI Proposition
Petrikas
Re: UI Improvements / Vertical UI Proposition
Post by Petrikas »
Some more improvements on @turn211 stylesheet. I've added a comment containing "VertUI" and changes done to the stylesheet, if you are curious.
Here's good ol' vanilla FreeCAD 0.20 @ 1080p:
FreeCAD Linkstage3 @ 1080p:
If you want to give the stylesheet and toolbars a go, copy over the stylesheet, and copy the expand_arrow.svg to the folder:
FreeCAD\data\Gui\Stylesheets\images_dark-light
Move your toolbars to the right first, then run this macro to lock them in place (to align the icons in a grid):
from PySide2 import QtCore, QtGui, QtWidgets
import FreeCAD as App
import FreeCADGui as Gui
mw = Gui.getMainWindow()
for k in App.ParamGet("User parameter:BaseApp/Workbenches").GetString("Enabled").split(','):
    if k != "":
        Gui.activateWorkbench(k)
        tbs = mw.findChildren(QtWidgets.QToolBar)
        for t in tbs:
            if t.isMovable():
                t.setMovable(False)
You can try the stylesheet without moving the toolbars to the right, just make sure to get rid of the WB dropdown and lock the toolbars in place with the script.
The macro takes a second, as it traverses through the WBs, but you only have to run it once every FreeCAD launch.
Feeling rather confident that we can get the UI to a state where people don't dismiss FreeCAD just based on its UI. Hoping these tweaks don't get dismissed.
[12/06/2020: updated with parameget, to traverse through active workbenches only]
ProDark VertUI.zip
Fixed a weird glitch in the Taskpanel for Link users
(11.53 KiB) Downloaded 111 times
expand_arrow.svg
(2.22 KiB) Downloaded 113 times
I sometimes make FreeCAD Tutorials | VertUI | MidnightUI
Petrikas
Post by Petrikas »
Fixed a couple of small issues with turn211's stylesheet, for both FreeCAD and FreeCAD Link, added a few lines to the stylesheet:
QSint--ActionGroup QFrame > QWidget > QLabel {
	background-color: transparent;
QSint--ActionGroup QFrame > QWidget > QGroupBox > QLabel {
FreeCAD Before:
FreeCAD After:
Link Before:
Link After:
Petrikas
Post by Petrikas »
I'm also having a lot of issues with the Draft Tray. It's a "Godmode" toolbar that cannot be disabled (At least in Vanilla FreeCAD), and even if FreeCAD Link allows it to be disabled, it spawns again whenever the Draft Workbench is activated.
It's also the only toolbar that has text, and cannot be vertical-ized. It's really unwieldy as it does not conform to anything.
Can I report this as a bug?
sc 2021-06-04 13_48_35.jpg (11.38 KiB) Viewed 5700 times
Post by Kunda1 »
I've seen something similar to this in the appimage but draft workbench wasn't loaded. Anyway, let's let @yorik know first since this is his 'baby' IIRC
yorik wrote: Ping
Post by Kunda1 »
Petrikas wrote: Fri Jun 04, 2021 10:36 am Fixed a couple of small issues with turn211's stylesheet, for both FreeCAD and FreeCAD Link, added a few lines to the stylesheet:
turn211 wrote: heads up
turn211
Post by turn211 »
Kunda1 wrote: Fri Jun 04, 2021 7:08 pm
Cool! As I'm more into Architecture I totally miss some of the 3d elements. Looks good. The XYZ's look lonely. Maybe Text align right wood help.
Petrikas
Post by Petrikas »
I've released a video on how to set this UI up in FreeCAD Linkstage3 and added written instructions.
Forum post up in General discussion, as this is not related to the original FreeCAD.
https://forum.freecadweb.org/viewtopic.php?f=8&t=55779
Malsasa
Post by Malsasa »
Excellent, I like this UI modification.
carlopav
Post by carlopav »
Petrikas wrote: Wed May 19, 2021 1:34 pm Tooltips
Problem: For some reason, tooltips, by default only include the description of the tool, but not the name. And the same description is also reflected in the status bad (disabled in my screenshots, as I don't find there's any useful information for the amount of space it takes on the screen)
Solution: Include the tool's name in the tooltip in bold. Tool description can be placed below.
Currently achieved with this hacky macro:
class NewToolTips(QtCore.QObject):
    # Find Toolbars
    for tb in mw.findChildren(QtWidgets.QToolBar):
        # Find Toolbar Buttons
        for x in tb.findChildren(QtWidgets.QToolButton):
            # Tool Name
            TTTitle = f"<b><p style=\"font-size:20px\">{x.text()}</p></b>"
            # Tool description
            TTTooltip = f"<p style=\"font-size:16px\">{x.toolTip()}</p>"
            # Build the Tooltip
            ntt = (f"{TTTitle}{TTTooltip}")
            # Set the Tooltip
            x.setToolTip(ntt)
    # Run indefinitely
    def run():
        for x in mw.findChildren(QtWidgets.QToolBar):
            NewToolTips(x)
NewToolTips.run()
Hello!
I was experimenting in including some of your improvements in the main branch :)
Here is for example the tooltip improvement: https://github.com/FreeCAD/FreeCAD/comp ... s?expand=1
C++ it's not my language, but it kinda works :)
Did you also experience some duplicated command names for some actions?
Petrikas
Post by Petrikas »
carlopav wrote: Sat Jul 31, 2021 11:41 am
    # Find Toolbars
            # Tool Name
            # Tool description
            # Build the Tooltip
            # Set the Tooltip
            x.setToolTip(ntt)
    # Run indefinitely
    def run():
            NewToolTips(x)
NewToolTips.run()
Hello!
Hi!
There's a whole bunch of things that don't work with the tooltips I made... :
- Tooltips get refreshed (reset) every time a tool is used, tools that were disabled (gray) get a double name (like in your gif)
- Some tooltips already have a name in the tooltip, resulting in multiple names
- Tooltips that have formatting (break lines, etc.) get put in a single line
- Some tooltips have hard-coded hotkeys that don't change when you change the hotkey in the parameters.
Great job on implementing this! Not having toolnames is much worse than having double names :D
