[SOLVED] issue #6244 [MacOS][view panel] Arrows of data properties overlap with scroll bar
Re: issue #4716 [MacOS][view panel] Arrows of data properties overlap with scroll bar
I DL weekly builds from https://github.com/FreeCAD/FreeCAD-Bund ... kly-builds
OS: macOS 10.16
Version: 0.20.25429 (Git)
Hash: acce57a25d82b0408fa07b9452ed31c8a06c7a1b
Python version: 3.9.6
Qt version: 5.12.9
OCC version: 7.5.2
Locale: C/Default (C)
Just got the latest version right now : it still overlaps and the scroll bar is still persistent (and still is over the other arrows/edit button) :
OS: macOS 10.16
Qt version: 5.12.9
OCC version: 7.5.2
- Screen 0.20.25429.png (70.71 KiB) Viewed 5152 times
Find your user.cfg and system.cfg files : Macro_findConfigFiles
Imperial system makes no sense, go metric ! ! !
I don't know who is making those Mac bundles, maybe the best way forward here is to try to get them compiled against the more recent libraries.
looo wrote: pinged by pinger macro
I think this needs to be adressed via the qt-feedstock:
https://github.com/conda-forge/qt-feedstock
maybe someone can create an issue. Or mayber there is already an issue related to this topic.
There is an issue there related to updating to 5.12.10, anyway: https://github.com/conda-forge/qt-feedstock/pull/189
I have no idea if that will fix it, though, I was testing on a much newer version.
Re: issue #6244 [MacOS][view panel] Arrows of data properties overlap with scroll bar
Can you try again:dxp.dev wrote: ↑Wed Aug 11, 2021 8:17 pm I DL weekly builds from https://github.com/FreeCAD/FreeCAD-Bund ... kly-builds
also
https://github.com/FreeCAD/homebrew-fre ... git-master
Comparing the 2 will could give us more comprehension about what the issue may be
Hi, I will try next week, kinda busy right now. I'll let you know.
So I tested the 2 and the scrolling bar still overlaps the arrows on both versions.
I noted that some (but not all) arrows have a space so that they are a little more to the left, but not enough to put them away from under the scrolling bar.
The same issue appears with the horizontal scroll bar : see in the screenshot how the element "LinearPattern001" is under the horizontal scroll bar. The last element of the tree is unreachable if the scrolling bar. The workaround is to expand the sidebar until the bar disappears (which can be wide when using description, taking real estate from the model window.
OS: macOS 10.16
Version: 0.20.28671 (Git)
Python 3.9.12, Qt 5.12.9, Coin 4.0.0, OCC 7.5.3
This may depend on MacOS System Preferences->General->Show scroll bars.
