[Merged] Ticket #4664 - Sketcher (and other WBs) tooltips have hard-coded hotkey hints
Re: Ticket #4664 - Sketcher (and other WBs) tooltips have hard-coded hotkey hints
Great work you guys! Thank you so much for your time and skills.
I'm seeing many people reporting that the hard-coded hotkeys have been fixed. They absolutely might have been fixed, I'm mainly working with Realthunder's build, which still have the hardcoded shortcuts, in Sketcher, for example.
I assumed that's a main branch problem, I might have been wrong, or things got fixed in the meanwhile.
Either way, my apologies.
P.S. I'm so happy that you guys are working on the UI. The tooltips will be great help to me (and hopefully everyone). Hope to do some thorough testing this weekend (tooltips + themes)
They were sort of fixed - they weren't so much "hard coded" in the sense that they were not actually explicitly in the tooltip, someone did write the code to try to pull the correct accelerator into the tooltip. But that code was running only when the commands were created, not when they were updated by the code that was reading the preferences file. So half of the fix was already there, this PR is just a matter of making sure to recompute the tooltips when the accelerators are loaded, or changed manually.
Hi Chris,chennes wrote: ↑Wed Aug 25, 2021 7:28 pm OK, this should fix it, no retranslation required:
https://github.com/FreeCAD/FreeCAD/pull/4995
wow, that was really a quick fix
I can confirm it resolves the tooltip style issue.
Doing some more testing I discovered another one:
- when I use the "assign"-button or the "clear"-button of the "Tools/Customize/Keyboard"-dialog everything is fine.
- but when I use the "reset"-button and the "reset all"-button shortcuts update only in the menu-text and not in the tooltip-text. For this a FreeCAD restart is required.
OK, I've pushed an addendum to that PR that addresses that bug -- the old code wasn't attempting to recreate the tooltips at all in those two cases, so I just added calls to the new recreate() function.balrobs wrote: ↑Thu Aug 26, 2021 6:15 am Doing some more testing I discovered another one:
The question is now, if we pull the trigger on this PR...are the tooltip translations b0rked or can we circumvent the issue somehow? (can we modify the .ts files before upping them in to crowdin so that the changes are already made ? (or is that a useless move?)
This does not affect the translations at all, it should pull in the correct ts info automatically.
Great!!!
...and it's merged. Thanks everyone for testing.
Re: [Merged] Ticket #4664 - Sketcher (and other WBs) tooltips have hard-coded hotkey hints
