PR#4999 Group view commands in toolbar
Since the introduction of the Navigation_Cube, the user have a quick way to change the view. Therefore there is not the necessity anymore to have 7 view buttons in the toolbar to access the functions that are easily usable through the Navigation_Cube.
Grouping them under a common goes in the direction of saving real estate in the FreeCAD window.
https://github.com/FreeCAD/FreeCAD/pull/4999
I created the PR cause I remember more than one request in this direction, and someone was writing that probably if it was not already implemented it was only because anyone thought it was urgent. Even so, I can't find again the conversations. Anyway I thought it was an low hanging fruit for my very bad c++ skills.
Re: PR#4999 Group view commands in toolbar
What about the users who do not use the cube?
If they used the toolbar buttons and not the keyboard shortcuts, They will have One click more...
Inconvenient for commands that are used very often.
ok, got your point. Let's wait for other feedbacks
Yorik suggested:
I agree this could be the right way..I have some doubts about this, because the very idea of having these buttons in a toolbar is to have them explicitly shown so it's a one-click to switch from one view to another. Given that the navicube can be turned off, this bar then takes all its sense...
I would suggest doing something else, then: Isolate them in a separate toolbar, so a user can simply turn it off. What do you think?
- adrianinsaval
is there a way of deciding if one wants it in a submenu or a full toolbar? In CATIA this is the case for several toolbars were you can choose the expanded toolbar or the collapsed toolbar (or even both if for some strange reason you wanted to). Of course, power users can just create a custom toolbar with those buttons if they really want them.
Perhaps having it in the submenu AND in an additional toolbar that can be turned off? So the dropdown also function as the Axonometric button...
Edit: the measure tool should stay in the first toolbar...
Having a preference that change one only toolbar seems a bit too much for this particular case...
Loving this solution. I think putting it into a dropdown might be too much clicking (thinking about a user that has the view-cube off and doesn't use hotkeys).carlopav wrote: ↑Mon Aug 30, 2021 5:17 pm Perhaps having it in the submenu AND in an additional toolbar that can be turned off? So the dropdown also function as the Axonometric button...
Splitting the "View" toolbar and hiding the actual views toolbar by default (leaving it for the user to turn it on, if they wish) would be an ideal solution from my point of view, because right now the default UI loads both view buttons and cube, which is overwhelming / disorienting / redundant.
That's a really neat idea. I wonder if we could easily implement this for ALL toolbars, so it's a baked-in option for everything: full toolbar, dropdown, and hidden completely.adrianinsaval wrote: ↑Mon Aug 30, 2021 4:47 pm is there a way of deciding if one wants it in a submenu or a full toolbar?
