Icons for User Edit Mode
openBrain
Post by openBrain »
Coming from :
bitacovir wrote: Sat Sep 04, 2021 7:14 pm Can you open a request in the UIUX forum, please? I am a bit busy these months, so I am working slow but happy to help. Just write the info about what icons you need.
Here you are.
The context is to get a set of icons for newly introduced Std_UserEditMode.
Obviously the first requirement is that each icon shall denote its own "name/function", respectively :
* Default
* Transform
* Cutting
* Color
As a common requirement, they should also denote they are link to the feature "editing", so probably using some kind of pencil as a universal symbol could be right, as in Std_Edit.
Finally ideally, icons should commonly denote that they represent an "action mode", in the sense that no action is performed directly by selecting one or the other mode, but it influences how the software will behave.
You can eventually have a look at the temporary icons I used (they are copied from existing FC resources), which IMO are not so bad, but definitely not so good. :)
I pinged @bitacovir because he asked for a topic, but anybody that want to participate is welcome. ;)
bitacovir
Re: Icons for User Edit Mode
Post by bitacovir »
openBrain wrote: Sun Sep 05, 2021 7:16 pm Coming from :
Here you are.
* Default
* Transform
* Cutting
* Color
I will bring a proposal during this weekend.
::bitacovir::
Canal Youtube Grupo Telegram de FreeCAD Español
My personal web site
My GitHub repository
Mini Airflow Tunnel Project
openBrain
Post by openBrain »
bitacovir wrote: Fri Sep 10, 2021 11:24 am I will bring a proposal during this weekend.
:+1: It's done when it's done :)
bitacovir
Post by bitacovir »
openBrain wrote: Fri Sep 10, 2021 11:41 am It's done when it's done :)
Proposal for Std_EditModeDefault icon
(The pencil will be present in all icons).
::bitacovir::
openBrain
Post by openBrain »
bitacovir wrote: Sat Sep 11, 2021 8:47 pm Proposal for Std_EditModeDefault icon
If I'm totally honest, I'm not fully satisfied with the 'd' representing 'default'. I'd like something more graphic/visual. ;)
However you have to consider :
* I'm totally idiot regarding UI/icons design
* This is already far better that what I used to submit the PR
So please continue in this direction to provide the full set, it's definitely good work. :)
carlopav
Post by carlopav »
If It can be of some help i did a small search, and many times a default value is presented with a grey check in the background of the icon...
default scanner.jpg (4.75 KiB) Viewed 5055 times
bitacovir
Post by bitacovir »
openBrain wrote: Sun Sep 12, 2021 7:08 am If I'm totally honest, I'm not fully satisfied with the 'd' representing 'default'. I'd like something more graphic/visual. ;)
I am not fan of letters in icons, but I don't find a symbol to represent the "Default" term. :)
What about this one:
::bitacovir::
openBrain
Post by openBrain »
bitacovir wrote: Sun Sep 12, 2021 11:04 pm I am not fan of letters in icons, but I don't find a symbol to represent the "Default" term. :)
How about a gray check mark?
Anyway, maybe it would be good to make the 3 other icons, and eventually it will give some idea about this one. :)
carlopav
Post by carlopav »
perhaps it could also be useful to think about what the default is:
Default: the object will be edited with its default mode. The edit mode is defined internally to be the most appropriate according the object type
so maybe also a grayed part feature icon (as a representation for an undefined object) could be the case?
bitacovir
Post by bitacovir »
openBrain wrote: Mon Sep 13, 2021 11:34 am
Proposals for
Std_UserEditModeTransform
Std_UserEditModeCutting
Std_UserEditModeColor
::bitacovir::
