I have a suggestion for the SVG for CarbonCopy. Could it be adjusted to have a solid line for the shape in the background?
I get the intent with the quasi-dotted line, but at icon size on the wiki the blue shape looks fuzzy IMO.
On the contrary the ToggleConstruction SVG is more crisp as its blue dotted shape is more uniform in its color combination (blue and darker blue).
To not have both symbols look the same the CarbonCopy could be say red and black or red and grey with the foreground shape, while the ToggleConstruction could retain the red/blue combination.
Example below, you can also see a "live" example on the Wiki on my user page.
Attached also the SVG.
Icon suggestion for CarbonCopy
- JoeKundlak
Joe
translating into SK: https://wiki.freecadweb.org
Re: Icon suggestion for CarbonCopy
Hi. I like it.JoeKundlak wrote: ↑Fri Nov 26, 2021 12:03 pm I have a suggestion for the SVG for CarbonCopy. Could it be adjusted to have a solid line for the shape in the background?
Is it following the FreeCAD artwork guidelines?
http://wiki.freecadweb.org/Artwork_Guidelines
Lets see if there is consensus to change this icon with a PR.
::bitacovir::
My personal web site
My GitHub repository
Mini Airflow Tunnel Project
- adrianinsaval
why 3 sketches in the icon though? shouldn't it just be one white/black one white/red? Otherwise I agree.
- JoeKundlak
Will check the Guidelines and report back!bitacovir wrote: ↑Fri Nov 26, 2021 12:48 pm Hi. I like it.
Thought it could confuse someone if just two shapes were present as it is a bit similar to the aforementioned ToggleConstruction icon. But if the consensus will be to have just one copy, sure, why not? Can do an image with just one, will post it later today...adrianinsaval wrote: ↑Fri Nov 26, 2021 1:19 pm why 3 sketches in the icon though? shouldn't it just be one white/black one white/red? Otherwise I agree.
Joe
- JoeKundlak
Icon with just one copy in the background, 2 versions (spacing different).
Joe
- adrianinsaval
IMO the current red and blue icon is easier to confuse with it.JoeKundlak wrote: ↑Fri Nov 26, 2021 1:40 pm Thought it could confuse someone if just two shapes were present as it is a bit similar to the aforementioned ToggleConstruction icon. But if the consensus will be to have just one copy, sure, why not? Can do an image with just one, will post it later today...
Just brainstorming here:if the white one is in front I think it will be easier to distinguish, does it make sense putting that in front?
Thanks for the initiative. This is exactly the issue I have with the current icons. All your suggested icons are a major improvement, I personally prefer the 3-shape versions.JoeKundlak wrote: ↑Fri Nov 26, 2021 1:40 pm a bit similar to the aforementioned ToggleConstruction icon.
- JoeKundlak
You mean like this?adrianinsaval wrote: ↑Fri Nov 26, 2021 5:01 pm Just brainstorming here:if the white one is in front I think it will be easier to distinguish, does it make sense putting that in front?
I cannot claim I invented the looks, I just iterated on JoshuaCall's icon (ToggleConstruction.SVG).
I too am more fond of the 3-shape design as it is more distinguishable to the many 2-icon ones currently present.
Joe
