combo view only shows task
The combo view only show Task, it does not show Model.
Re: combo view only shows task
Then it's probably not the combo view.
More info would help, e.g. a screenshot and you should attach your full FreeCAD info as described in the IMPORTANT forum rules linked above.
In Preferences->General->General there is an popup where you ca choose where you want the tree view to show up.
It is labeled "Tree view mode:"
You may need to restart FreeCAD or hide/show the Combo view to reflect changes.
This is all i get when combo view is on. This is on windows 11 pro.
Let me know if there is anything else i can supply to you.
OS: Windows 10 (10.0)
Version: 0.20.28793 (Git)
Python 3.8.13, Qt 5.12.9, Coin 4.0.0, OCC 7.5.3
- adrianinsaval
right click on an empty space in the toolbar area and check to show the tree and property view
Went to the latest build and in Combo View - Model and Task View are back and working
Thank You.
Thank You.
Version: 0.20.28857 (Git)
This exactly is how it looks like when Preferences->General->General->Tree view mode is set to "Treeview and PropertyView". Did you check this? I use this setting so that I don't have double tree views and can have the treeview visible all the time.
Yes, It did not mater which way i had it [Combo View], [Treeview and PropertyView] or [Both]. I had upgrade to the latest version of Windows 11 pro. With it installed on the machine. I pull the newest build back off and and remove all directories FreeCad uses in the hidden directory [User][AppData] and reinstalled [Build 28857] it was working again. It could have been a file that got corrupted during the Windows upgrade. I like trying to keep up with the latest build that is made to see what is new and working. I am back on the [Build 28871} now. Sorry to have bother you with this. I should have deleted the hidden directories first. They are in [C:\User\Bob\AppData\Roaming\FreeCad] and [C:\User\Bob\AppData\Local\FreeCad]
- adrianinsaval
