Preference Pack testing issues
turn211
Post by turn211 »
Trying to test my new ProDark Theme Pack https://github.com/turn211/ProDarkThemePreferencePack I'm presently working remotely on a construction project and only have access to a sort of public computer but was able to create a Preference Pack and stylesheet that corrects all the bugs and nags about ProDark theme on this Forum. I can only use the Github web gui and installed FreeCAD Conda. So i want to download the ProDarkThemePreferencePack.zip and manually install it. I created ~\AppData\Roaming\FreeCAD\Preference Packs and Unzipped. Nothing. Got rid of the nesting folder. Nothing. Does not show up in Preferences upon FreeCAD restart. Any ideas. Here is a sneek peek.
OS: Windows 10 (10.0) wrong actually Windows 11
Version: 0.20.28793 (Git)
Python 3.8.13, Qt 5.12.9, Coin 4.0.0, OCC 7.5.3
Installed mods:
  * A2plus 0.4.56
  * Assembly3 0.11.3
  * Assembly4 0.11.12
  * BIM 2021.12.0
  * fasteners 0.3.41
  * FreeCAD_InspectWidgets-master
  * Help 1.0.0-alpha
Tool Library Bliss.png (241.46 KiB) Viewed 1914 times
chennes
Re: Preference Pack testing issues
Post by chennes »
You have a typo in your XML: see PR https://github.com/turn211/ProDarkTheme ... ack/pull/2
Chris Hennes
Pioneer Library System
turn211
Post by turn211 »
chennes wrote: Thu May 19, 2022 2:34 pm You have a typo in your XML: see PR https://github.com/turn211/ProDarkTheme ... ack/pull/2
Thanks. I merged your commit and downloaded the zip. Unzipped, but still doesn't show up in the Preference panel. Any ideas?
chennes
Post by chennes »
Try installing it via the Addon Manager instead -- it's working fine for me. Also, I notice you have a font set in there, for the console -- that's generally not a good idea, since systems vary widely in what fonts they have available. I'd suggest just dropping that setting from the pack.
Chris Hennes
turn211
Post by turn211 »
chennes wrote: Thu May 19, 2022 3:23 pm Try installing it via the Addon Manager instead -- it's working fine for me. Also, I notice you have a font set in there, for the console -- that's generally not a good idea, since systems vary widely in what fonts they have available. I'd suggest just dropping that setting from the pack.
Thanks. I don't know how install it via the Addon Manager. I'll make an icon, strip out the font settings, and submit a PR and trust you that it works.
chennes
Post by chennes »
If you edit the Addon Manager's preferences to add the following line to the list of external repos, it should show up next time you launch the AM:
https://github.com/turn211/ProDarkThemePreferencePack main
Chris Hennes
turn211
Post by turn211 »
I unzipped into
~\AppData\Roaming\FreeCAD\Mod
instead of the WIKI recommended
and it works fine. PR shortly. Thanks
turn211
Post by turn211 »
chennes wrote: Thu May 19, 2022 3:57 pm If you edit the Addon Manager's preferences to add the following line to the list of external repos, it should show up next time you launch the AM:
That worked too. Thanks for all your help. Have a great day!
