Can't we use the current line highlight color from the editor from settings?
[Issue] Multiline Textfield with Dark Themes
- MisterMaker
Re: [Issue] Multiline Textfield with Dark Themes
OK, obviously I messed here something up writing without sitting in front of a computer.balrobs wrote: ↑Wed Aug 03, 2022 11:36 pm I think that giving up the highlighting feature would cause troubles to many users.
Imagine the case a user selects all words in a single line. The visual feedback would be a blinking coursor at the end of the line. So pressing DEL he could expect to delete only the last letter of that line.
Hope my thinking makes sense.
Cheers
I confused the text-highlighting with the line-highlighting. Sorry for that
In this circumstance I would support obelisk79's suggestion to remove the yellow line markers.
When I create or double-click a Draft_Text I see this Input-Widget: But when I use the Three-Dot-Button in the Data Tab I see this List-Widget: IMHO line numbers and line highlighting don't add any value for the vast majoritiy of cases I can think.
Cheers
- wandererfan
That won't follow the stylesheet.MisterMaker wrote: ↑Fri Aug 05, 2022 6:19 pm Can't we use the current line highlight color from the editor from settings?
This seems to follow the stylesheet. The screen grab is Behave-dark and the video is Dark-orange. A difference from the current version is that it doesn't highlight anything until there's a click in the text area.
- PropertyListEditor_darkOrange.webm
- (94.46 KiB) Downloaded 58 times
- PropertyListEditor_behaveDark.png (5.17 KiB) Viewed 1809 times
Is there a way to determine which PR this is, and if it was accepted? I'm still experiencing the yellow background with white (hard to see) text for multiline input with ProDark theme, as mentioned in my post: https://forum.freecadweb.org/viewtopic.php?f=35&t=74384
The post is about something else, but I mentioned this issue, because I thought it was related at the time. Screenshots and version info included in that post. Thank you for all the work you do,
- wandererfan
There was never a PR, just a discussion. Is this better?maltMan wrote: ↑Wed Dec 14, 2022 5:37 am Is there a way to determine which PR this is, and if it was accepted? I'm still experiencing the yellow background with white (hard to see) text for multiline input with ProDark theme, as mentioned in my post: https://forum.freecadweb.org/viewtopic.php?f=35&t=74384
- accessibilityAnnotationEdit.png (10.59 KiB) Viewed 1405 times
- MisterMaker
Would be nice if this could be fixed so we won't have this discussion again in couple of months
- adrianinsaval
I suggest creating a new empty line at the end always and make it editable, once it has content automatically create a new empty line and so on.wandererfan wrote: ↑Thu Dec 29, 2022 7:50 pm There was never a PR, just a discussion. Is this better?
Yeah, that looks great!wandererfan wrote: ↑Thu Dec 29, 2022 7:50 pm There was never a PR, just a discussion. Is this better?
