- Position_MouseInterface.png (21.18 KiB) Viewed 917 times
The when I change the Placement/position/X parameter for any object I have two mouse wheel functions
- wheel = change value in mm
- CTRL-wheel= change value in 10x mm
What I am missing is a way to do 0.1x mm, e.g.
- SHIFT-wheel = change value in 0.1x mm
I guess its a core function. If that is added thoughout the whole interface I would think this is even better.
Maybe worth discussion is the assignment. Possibly more intuitive could be to change the current assignment
- SHFT-wheel -> value change is larger
- CTRL-wheel -> value change is smaller
Other packages also use the ALT-mouse for very fine movements. This may be a problem in Linux, i.e. I find that my xfce installation by default uses the "wheel-ALT" to zoom the desktop. If FreeCAD can not override that it would be very confusing to people to find that this combination does not work out of the box.
What do you think? Has this been discussed before?
