FC v0.20.0 - duplicate selected object : TreeView elements seem redundant
DeeJayOne
Post by DeeJayOne »
Hi everyone :)
I'm asking if there is not an issue with the content of the TreeView of the "Object Selection" window after executed the "Edit -> Duplicate selected object" feature.
A simple example by just create a body, a sketch with a simple shape and a pad.
Then duplicate the body to open the "Object Selection" window.
FC_v0.20.0 - Duplicate_Body_All_elm_arbo_2a - (with borders & arrows).PNG (77.81 KiB) Viewed 984 times
As you can see, there are lot of redundant elements in the TreeView : Why not just show only these elements to be more clear ?
FC_v0.20.0 - Duplicate_Body_All_elm_arbo_2a - Nice to have.PNG (62.23 KiB) Viewed 984 times
OS: Windows 10 Version 2009
Version: 0.20.29177 (Git)
Branch: releases/FreeCAD-0-20
Locale: French/France (fr_FR)
FC_v0.20.0_Duplicate_Body_save_01_OK_before_duplicate.FCStd
(9.85 KiB) Downloaded 34 times
L'important est de ne pas arrêter de poser des questions. La curiosité a sa propre raison d'exister
The important thing is not to stop questioning. Curiosity has its own reason for existing.
Albert Einstein
DeeJayOne
FC v0.20.0 - Duplicate selected object : GeoFeatureGroup Exception
Post by DeeJayOne »
Hi Everyone ;)
For a while, I meet an issue by trying to duplicate a body with the "Edit -> Duplicate selected object" feature.
As an example, just create a body with a sketch and a pad.
Then, try to use the "Duplicate selected object".
It will show you an "Object selection" window.
Keep the default settings (All elements) and click OK.
a dialog box appears with the following message : Object can only be in a single GeoFeatureGroup
PS : Sometimes, this issue seems to appear randomly
Capture d’écran (4323).png (231.59 KiB) Viewed 987 times
Albert Einstein
Re: FC v0.20.0 - duplicate selected object : TreeView elements seem redundant
When I duplicate the body, I get a message "Object can only be in a single GeoFeatureGroup", but then everything looks as expected:
Only the attachment of the duplicated sketch references the plane from the first body.
Edit: some information given here may be redundant after the merge of the two topics.
I have merged your two topics. Please sort the contents and remove doublettes.
DeeJayOne
Post by DeeJayOne »
chrisb wrote: Sat Aug 13, 2022 11:27 pm I have merged your two topics. Please sort the contents and remove doublettes.
I thought it would be clear to separate each issue.
I'd rather keep initial post in their original state, otherwise, I will have to spend lot of time with a risk to make it incomprehensible.
Albert Einstein
DeeJayOne
Post by DeeJayOne »
chrisb wrote: Sat Aug 13, 2022 11:20 pm Only the attachment of the duplicated sketch references the plane from the first body.
Yes, behaviour depend of selected elements :
Body (+Sketch and Pad at root level)
Combo Body - with arrow.png (76.22 KiB) Viewed 849 times
Body (+Sketch and Pad at root level) + Sketch Plane link
Combo Body + Sketch Plane link - with arrow.png (72.26 KiB) Viewed 849 times
All elements (default selection)
Combo All Elm - with border.png (259.47 KiB) Viewed 849 times
Albert Einstein
