Target Spreadsheet Aliased Cell Color through .qss? (FreeCAD 0.20.1)
Axeia
Post by Axeia »
I'm working on a Dark Theme as all the included dark themes weren't quite dark enough for my tastes and many had weird little glitches.
My theme is based on the by default included Dark-Contrast one, I am running into a problem with aliased spreadsheet cells. By default these have a yellow background color, as I have set my spreadsheet cells to have a white foreground (font) color this gives me white on yellow which is unreadable.
If I set a background-color on all spreadsheet cells the yellow color gets overwritten but then aliased cells don't stand out.
ImageDoomed if I do, doomed if I don't. Is there a way to target an aliased cell specifically? Does it have a special attribute that can be targeted?
I have tracked down the line of code in FreeCADthat sets the yellow color if no background color is set over here:
https://github.com/FreeCAD/FreeCAD/blob ... el.cpp#L56
aliasBgColor = QColor(Base::Tools::fromStdString(hGrp->GetASCII("AliasedCellBackgroundColor", "#feff9e")));
Which seems to mean if the cell has a background color, use that, if not make it yellow.
I have no experience with Qt/C++ so I'm not quite sure what good this does me other than figuring out that aliased cells have a tooltip and perhaps elements with a tooltip can be selected through QSS somehow. Unless I'm overlooking it there doesn't seem to be anything set on the cell that would be equal to the CSS equivalent of a class.
Can anyone that's more knowledgeable about Qt/C++ help me out here? Can I target aliased cells in qss somehow? Should I submit a feature request on github for it to be added if not?
[edit]
I tried (to no avail)
QTableView::item[tooltip], QTableView::item[toolTip], QTableView::item[Tooltip]{
    background: black;
onekk
Re: Target Spreadsheet Aliased Cell Color through .qss?
Post by onekk »
Hello, maybe it is something similar to this problem:
https://forum.freecadweb.org/viewtopic.php?f=34&t=50744
Probably a less verbose title will make clear that you can't find a way to change a color.
As from the post linked seems that something has been changed, and your post is not telling what FC version you are targeting it is hard to tell if using latest dev version (if changes are already packaged for OS you are using) it will solve this problem.
Regards
Carlo D.
- Various other stuffs.
Post by Kunda1 »
An aside, @Axeia can you share the location of your repo. I'd like to add you to https://github.com/FreeCAD/FreeCAD-addons/issues/201 if you don't mind?
MisterMaker
Post by MisterMaker »
It's btw weird that below text has the correct white color if you don't use the setting.
But it also changes when you add the setting, feels like that text has some parameters that spreadsheet text should have.
adrianinsaval
Post by adrianinsaval »
it's using the same widget type as the spreadsheet probably.
MisterMaker
I tried this:
QTableView {
  qproperty-AliasedCellBackgroundColor: #f700ff;
  qproperty-aliasBgColor: #f700ff;
And some versions of that code, but non worked. Not sure why it doesn't work.
chennes
Post by chennes »
The aliased cell background color is set in User.cfg, not in the QSS file, unfortunately. It sounds like a good adjustment to me, to make that a QProperty that can then be set via QSS, however.
Chris Hennes
Pioneer Library System
MisterMaker
chennes wrote: Mon Oct 03, 2022 6:47 pm The aliased cell background color is set in User.cfg, not in the QSS file, unfortunately. It sounds like a good adjustment to me, to make that a QProperty that can then be set via QSS, however.
I thought it would be possible to set it true the preference pack settings but I also get no results.
I added this:
          <FCParamGroup Name="Spreadsheet">
            <FCUInt Name="aliasBgColor" Value="2105376255"/>
            <FCUInt Name="textFgColor" Value="2105376255"/>
            <FCUInt Name="positiveFgColor" Value="2105376255"/>
            <FCUInt Name="negativeFgColor" Value="4294967295"/>
          </FCParamGroup>
These settings are also not in the user.cfg.
chennes
Post by chennes »
You need to set "AliasedCellBackgroundColor".
Chris Hennes
Axeia
Post by Axeia »
onekk wrote: Mon Oct 03, 2022 7:55 am Hello, maybe it is something similar to this problem:
Regards
Carlo D.
Ah I ran into that post a bit earlier in my theme creating journey as that was indeed another thing that was a bit hard to style, but the DarkPro stylesheet actually manages to target that one so I copied the code from there for my own theme (I actually created a git pull request that fixes all the 'Darker' stylesheets fixing that one).
I should have indeed mentioned my FreeCad version, I'm on 0.20.1 (Revision 29410) and I'm using Windows 10.
I'll append it to the title but I'll leave the rest of it it as it is. It's succinct but should get the point across in this part of the forum :)
If changes are made to the FreeCAD code I'd be in support of simply adding a class named "alias" or "aliased" so themes can simply target it as
QTableView::item.aliased{
    background-color: teal;
It's a lot easier to read than the the whole "qproperty-AliasedCellBackgroundColor" syntax. It also makes it easier for people (like me) that have a CSS rather than a Qt Style Sheets background to understand what's going on.
