The Big TechDraw Comments Thread
Re: The Big TechDraw Comments Thread
Postby chrisb » Fri Aug 18, 2017 11:05 pm
Mongrel_Shark wrote:
Fri Aug 18, 2017 10:34 pm
but what if I want to change from one ppa to another or have both side by side
It's no problem to have both versions side by side. one is called freecad, the other freecad-daily. They only share the config files.
Mongrel_Shark
Postby Mongrel_Shark » Sat Aug 19, 2017 12:23 am
Sweeeet! Thank you very much for clarifying :D
Sam
Postby Sam » Sun Aug 20, 2017 1:19 am
I've been playing with the wonderful new TechDraw workbench. Its early days, but I like it!
OS: Ubuntu 16.04.3 LTS
Version: 0.17.11797 (Git)
Build type: None
Hash: a5080329d8da6653495df686efbda62e73ac950a
Python version: 2.7.12
OCC version: 7.1.0
Originally I was going to post in the help forum, but:
wandererfan wrote:
Thu Dec 08, 2016 9:43 pm
I kind of like everything in 1 place, easier to find.
There still seem to be issues caused by ignoring/not processing PDN Part/Super placement.
I see a couple of relevant posts starting over here, but those are from a year ago and I can't find any indication of progress.
This gargantuan thread doesn't touch on it, or I missed it in the 28 pages I just read.
The TechDraw Roadmap doesn't mention this either.
Is there a work around that I should be aware of?
efyx
Postby efyx » Thu Mar 29, 2018 7:19 am
wandererfan wrote:
Mon Mar 13, 2017 9:10 pm
Some loose suggestions to discuss about some improvements:
- Panning drawing sheet shouldn't be by LMP because by mistake you can move drawing window which is also movable by LMB. I suggest RMB or Scroll Wheel.
- Icons should be first choosable (as in sketcher) then lines or points, to create dimensions.
- Can spacemouse be added? To steer (left, right, up, down, zoom in and zoom out)
- Reversable angle dimension - inner/outer depends where mouse is (on which side, acute angle/ obtuse angle)
- Why object "surface" between lines is higlighting? I believe it is for some reason, but mainly this is not usable and it makes to choose lines harder. Could be an option - with additional icon.
- Detail circle position - I belive it is hard for now to implement dragging (also as cross section) on demand position right now, but maybe meanwhile it can be done as in cross-section that when you scroll anchor point of detail it automatically refresh on screen.
- Isometric view should could be deattached.
- Cylinder in top view should at least have quadrants (not only one point on the edge)
- There should be option to add (or default) to make point on extremum of radius.
- Should be added intersection point as shown on my sketch do dimension rounded objects. See below:
- Welding symbol generator?
Please comment.
herrdeh
Postby herrdeh » Wed Jul 11, 2018 8:51 am
This may have been asked several times, but my google did not find an answer:
Is it possible to edit the size of the black dots, which mark the nodes of objects? - For my taste they are a little big...
Cheers,
Wolf
ubuntu 18.04.1
HarryGeier
Postby HarryGeier » Wed Jul 11, 2018 10:21 am
Cheers,
Wolf
and a little too black...
( i loved the green dots from the older addon "drawing and dimensioning" ) wb
wandererfan
Postby wandererfan » Wed Jul 11, 2018 12:29 pm
Answered in this recent thread. There is a parameter that controls the scaling of the Vertex dots.
HarryGeler wrote: and a little too black...
green and yellow are taken for selected and preselected. Next time I'm fiddling with the preferences page I'll add a "Vertex Chromatic Adjustment". :D
HarryGeier
Postby HarryGeier » Wed Jul 11, 2018 1:07 pm
That´s good...
herrdeh
Postby herrdeh » Wed Jul 11, 2018 7:08 pm
Great. I'll try.
One more thing - I missed a arrow-annotation feature. Like diameter, but with editable text. Did I ignore it - or is it still under construction?
Anyway - thanks for this awesome WB. I used to like drawing dimension very much, but TechDraw's approach is much more handy, especially concerning views and angles. That was a little nightmare in DD, and you have such an intuitive solution. My compliments!
Wanderer - saxon vehicle factory - or Schubet's piano piece?
Cheers, Wolf
ubuntu 18.04.1
wandererfan
Postby wandererfan » Thu Jul 12, 2018 12:04 pm
This has been on the to-do list for over a year. It will get to the top eventually. Combining a LeaderLine with an Annotation would be relatively easy, but I have no elegant way of picking the point for the arrowhead at the moment.
herrdeh wrote: Anyway - thanks for this awesome WB. I used to like drawing dimension very much, but TechDraw's approach is much more handy, especially concerning views and angles. That was a little nightmare in DD, and you have such an intuitive solution. My compliments!
Thank you!
herrdeh wrote: Wanderer - saxon vehicle factory - or Schubet's piano piece?
Ice hockey team, actually.
