Dashed lines
jcp79
Dashed lines
Postby jcp79 » Wed Oct 10, 2018 7:48 pm
Hi Triplus
I'll try this like you said...thank you for advice
for now:
I need to do some circles with dashed lines, to indicate the radius for the fabricator drill some holes (like the old drawing, indicated by the pen)
How can I do this on techdraw WB or the drawing dimensioning WB?
any clue?
Captura de tela de 2018-10-10 16-25-44.png (71.39 KiB) Viewed 378 times
Re: Title Block Temp SVG Questions
Postby NormandC » Thu Oct 11, 2018 4:55 am
Okay, so this topic may be 2 years old, but it has nothing to do with FreeCAD development. It's clearly an end user matter, so it should not be in "Developers corner", but go in the "Help on using FreeCAD" forum.
And jcp79, your last question doesn't have anything to do with SVG templates, so you should have created a new topic.
Re: Dashed lines
Postby chrisb » Thu Oct 11, 2018 8:39 am
Split topic and moved to TechDraw forum.
jcp79
Re: Dashed lines
Postby jcp79 » Thu Oct 11, 2018 11:25 am
OK guys
I'm not used to use forums, so I will make some mistakes... :?
will do that NormandC
thank you for your help!
reox
Re: Dashed lines
Postby reox » Thu Oct 11, 2018 5:41 pm
