Preliminary (alpha) versions of TechDraw_CosmeticEraser and TechDraw_FaceCenterLine are available in master branch.
Test reports are very welcome.
CosmeticEraser and FaceCenterLine Alpha Release
- wandererfan
- wandererfan
Re: CosmeticEraser and FaceCenterLine Alpha Release
Known shortcoming: The editor for centerline isn't ready yet. Erase the old one and create a new one for now.
Both are fairly useful additions, thanks!
CosmeticEraser: Works great for me with all types of CosmeticVertices and FaceCenterLine. Small nitpick: Selecting a CosmeticVertex and pressing "Delete" on keyboard deletes the View, not the CosmeticVertex. Using the mouse button icon works fine.
FaceCenterLine: Worked great for all the faces I tested. However, I was able to select other objects, like edges or vertices, which caused some errors in report view after trying to make a FaceCenterLine and pressing the OK button (Unhandled unknown exception caught in GUIApplication::notify.) Also, I could not understand what the option "Aligned" should do, I did not find any difference to "Vertical" or "Horizontal" there.
Feature request: It would be nice to have numerical offset values for the FaceCenterLine in the config box, i.e. user defined horizontal and vertical offsets in mm for the centerlines, so that the centerline could be moved up, down, left or right as needed by the user.
Feature request 2: It would also be nice to have a tilted centerline with an angle offset (0 - 360°). Maybe this is what the option "Aligned" is planned for?
OS: Windows 10 (10.0)
Version: 0.19.16945 (Git)
Hash: d818a9638424a934bd9da74d187a1af4cb773f05
Python version: 3.6.8
Qt version: 5.12.1
- wandererfan
Not sure how to fix this off the top of my head. Will take a bit of digging.
Plans are to have centerline between two edges and perpendicular centerline between two vertices, so I didn't block selection of those geometries. Probably should put that in until edge/vertex CLs are ready.aapo wrote: ↑Tue Jun 11, 2019 6:51 am FaceCenterLine: Worked great for all the faces I tested. However, I was able to select other objects, like edges or vertices, which caused some errors in report view after trying to make a FaceCenterLine and pressing the OK button (Unhandled unknown exception caught in GUIApplication::notify.) Also, I could not understand what the option "Aligned" should do, I did not find any difference to "Vertical" or "Horizontal" there.
I like this idea. Will see what I can doaapo wrote: ↑Tue Jun 11, 2019 6:51 am Feature request: It would be nice to have numerical offset values for the FaceCenterLine in the config box, i.e. user defined horizontal and vertical offsets in mm for the centerlines, so that the centerline could be moved up, down, left or right as needed by the user.
So I would start with a CL of a Face, then rotate by X* about it's midpoint?
Great suggestions and comments. Thanks for testing.
wf
Exactly! That way one could add a centerline, when e.g. a screw hole or some other feature happens to be at 45° to the horizontal axis in a section drawing. It'd make sense to tilt the CenterLine to align to the hole. Thanks for coding!wandererfan wrote: ↑Tue Jun 11, 2019 11:39 am So I would start with a CL of a Face, then rotate by X* about it's midpoint?
Hello,
I use FreeCad occasionnely and I think cosmetic features can be a real help in drawing
For cometic FaceCenterLine, don’t you think it would be easier to select 2 edges and draw the middle line ...
With this method, edges even don’t need to be parallel nor equal lengh
2 parameters could be use to increase or reduce the size of each end of this line.
I hope m’y suggestion can help
- wandererfan
This is on the TODO list, actually, along with a "centerline" that splits the segment between two points.Stq_Niko wrote: ↑Fri Jun 14, 2019 7:39 pm For cometic FaceCenterLine, don’t you think it would be easier to select 2 edges and draw the middle line ...
In the case of a middle line between two edges, the current stumbling block is a fool-proof way of choosing the corresponding ends of each edge. If I choose the correct ends of the white lines, I get the green (correct) line. If I choose wrong, I get the fairly useless red line.
sorry,I didn't checked the to do list before write the message
Since you post the answer, I try to think how to build a center line of 2 edges and I realized that the problem is not as easy as it seem to be ...
The last few days I think about the CenterLine Fonction and Then I wondered what should this function do. For me, when we want a “center line” in a drawing we want in fact the symmetry axis (in general I think).
The symmetry axis of 2 different segments (edge) is not really possible, but it is possible for the lines that go through these segments. It is necessary in this case to construct the bisector of these 2 lines.
What do you think ?
What do you think ?
