Ticket #4396 - TechDraw templates disappearing.
WEMV
Re: TECHDRAW templates disappearing.
Postby WEMV » Mon Jun 29, 2020 7:15 pm
wandererfan
Your statement "a file selection dialog that changed directories without user input" is a good way to describe what I seem to be seeing. I already created my own directory per your suggestion. It works but is rather strange because the file selection dialog keeps changing.
I saw your Known OS specific issues but it did not dawn on me that it applied to this situation. Could you please explain how to use your workaround, I am rather confused.
Thank you.
Postby chrisb » Mon Jun 29, 2020 8:40 pm
It's these three steps:
1. Open Menu->Tools->Edit Parameters
2. Navigate to BaseApp/Preferences/Dialog
3. Create a boolean parameter named: DontUseNativeDialog and set its value to true.
Where do you get stuck?
WEMV
Postby WEMV » Mon Jun 29, 2020 9:46 pm
I follow your instruction up Create a boolean parameter. I can't seem to create the parameter.
Postby chrisb » Mon Jun 29, 2020 10:14 pm
I just tried to create such entry on a plain vanilla configuration which crashed FreeCAD, can someone please confirm:
- Start FreeCAD
- Open Tools->Edit Parameters
- Select BaseApp->Preferences->Dialog
- Righ-click in the right panel of the window
->Crash
WEMV
Postby WEMV » Mon Jun 29, 2020 11:29 pm
That's what happened when I tried.
Postby chrisb » Tue Jun 30, 2020 7:38 am
Please create a ticket in the bugtracker and crossreference this topic.
wandererfan
Postby wandererfan » Tue Jun 30, 2020 1:20 pm
I already had the DontUseNativeDialog set in my config file. That must be why my results were different.
Trying to add the parameter to an empty preference file fails here with:
OS: Linux Mint 19 (X-Cinnamon/cinnamon)
Version: 0.19.
Branch: unknown
Hash: ddf0cf3136a6c5a459abae4bf1f9c714f6f45c86
Python version: 3.6.9
Qt version: 5.9.5
Locale: English/Canada (en_CA)
WEMV
Postby WEMV » Tue Jun 30, 2020 6:02 pm
Created a bug ticket issue #4396.
Reason: added bug bbcode tag
maxi.mep
Postby maxi.mep » Fri Jul 03, 2020 1:27 am
I saved the templates in a personal folder in my Documents, I did the same with the hatch patterns...
Re: Ticket #4396 - TechDraw templates disappearing.
Postby Kunda1 » Fri Jul 03, 2020 10:35 pm
Mod edit: Added ticket number to thread title.
Is this just AppImage related ?
