[resolved] opinion wanted: disable tolerances when 'Theoretically exact' is True
uwestoehr
Postby uwestoehr » Mon Jan 11, 2021 2:15 am
When dimensioning one can mark dimensions as being theoretical exact, maybe to use them as reference of for calculations. TD supports this with the property "Theoretically exact". When this is True, a frame is drawn round the dimensions.
But at them moment we also allow this output:
This is weird since it contradicts the idea of the theoretically exact value. So when a dimension is theoretically exact it cannot also have tolerances. I googled around and had a look in the norms and I could not find a case where one has a theoretically exact dimension with tolerances specified.
However, before I "fix" this, I would like to hear if there are arguments that tolerances + theoretically exact is necessary.
davidosterberg
Re: opinion wanted: disable tolerances when 'Theoretically exact' is True
Postby davidosterberg » Mon Jan 11, 2021 6:13 pm
I say fix it, adding tolerance to a TED makes no sense
aapo
Postby aapo » Tue Jan 12, 2021 11:17 am
Agreed. Probably the best way to fix it is to simply skip printing the tolerances whenever "Theoretically exact" is selected. It seems to me, that there should not be tolerances with theoretical dimensions in any cases, classical or GD&T. Instead, GD&T rules and additional tolerancing should always be used for theoretically exact dimension tolerancing. And, since we now have a rudimentary support for GD&T boxes, this should be ok to be fixed.
https://www.globalspec.com/reference/43 ... dimensions
uwestoehr
Postby uwestoehr » Tue Jan 12, 2021 12:37 pm
Agreed.
Thanks, so I will make a PR fixing it.
aapo
Postby aapo » Tue Jan 12, 2021 12:42 pm
Thanks for working on TD! :D
