The Big TechDraw Comments Thread
wandererfan
Re: The Big TechDraw Comments Thread
Postby wandererfan » Fri Jul 05, 2019 12:03 pm
felixlee868 wrote:
Fri Jul 05, 2019 7:10 am
Right now, I need TechDraw can display "hide line" on perspective view and orthography view. I don't know why my part can not display hide lines ( After I setup use dot line display for TechDraw configuration
Display of hidden lines is controlled by the "HLR Parameters" of the View:
By the way. if I want add some function for the project, What books I need read? ( expect C++ and Python3 ? )
TechDraw is written in C++ but some functions are available in Python. You'll also need to know Qt, especially QtGraphicsScene.
Postby Kunda1 » Fri Jul 05, 2019 1:13 pm
There is an effort to develop a FC developer guide at https://github.com/qingfengxia/FreeCAD_Mod_Dev_Guide
felixlee868
Postby felixlee868 » Sun Jul 07, 2019 6:48 am
Thanks for wandererfan. I am rookie for FreeCAD. I just learning engineering Drawing knowleage. Lots knack about FreeCAD need to try.
Thanks FreeCAD proejct. I love it.
reox
Postby reox » Mon Sep 16, 2019 9:14 am
I think it is not worth it to create a own thread for this question:
Can you set the default font size for annotations? I have set the default font size to be 3.5mm, but if I create an annotation, the font size is always 8mm.
Or is there something in the Customize section to set?
There seems to be also a small bug, that the area for the annotation is not large enough to fully fit text which goes below the base line:
This only happens if there are characters like gpqy etc in the last line. A quick fix is to add a blank line at the end.
wandererfan
Postby wandererfan » Mon Sep 16, 2019 6:05 pm
The default size in Annotation is hard-coded to 8mm. I'll change it to use the default parameter.
It seems the LineSpace parameter doesn't apply to the last line of text. So even if you set it to 120%, the descenders get cropped. Your quick fix is probably the best choice. I'll see about adding a blank line automatically.
wandererfan
Postby wandererfan » Fri Sep 20, 2019 12:41 am
Should be fixed by git commit f76e74d2c1.
Annotation defaults to LabelSize preference and adds a blank line at the end automatically to allow room for descenders.
reox
Postby reox » Fri Sep 20, 2019 5:56 am
Very nice! Thank you very much!
Tandini
Postby Tandini » Thu Nov 28, 2019 1:05 pm
Hi, have a problem with Detail View:
Is there any chance to get rid of (or minimize) that huge white frame covering necessary parts of the drawing?
(Also in the exported PDF)
When I reduce the Radius < 300, I manage to place the Detail View that it doesn't cover the drawing frame, but the viewing area gets too small ...
Is it possible to set the visibility of the circle / square frame true or false?
Furthermore it would be very nice to define a rectangular viewbox with Width and Height properties.
btw: After switching from Drawing Dimensioning workspace to TechDraw I want to express my appreciation for the effort you're pushing into TechDraw!
OS: Windows 10 (10.0)
Version: 0.19.18778 (Git)
Hash: f55cf3ef103532c9718c108bd856a4ef06ad49a5
Python version: 3.6.7
Qt version: 5.12.1
wandererfan
Postby wandererfan » Thu Nov 28, 2019 8:20 pm
In the current implementation, I need a bit of a solid border to prevent "bleed through" of the perimeter of the detail cut. I might be able to shrink it a bit, but I can't make it go away. In a future version I could use some sort of clipping to trim the edges instead.
Not now. Would be fairly easy to add a property to control that.
Never thought of that one. I'm used to seeing circles (and rarely squares), but not rectangles. Is that common practice?
Thank you. That's nice to hear.
Tandini
Postby Tandini » Fri Nov 29, 2019 7:58 am
I don't think so. Circle is common practice.
In this special case I set up the complete assembly in a way to extract a step-by-step assembly instruction - each step on a single TechDraw page.
With a rectangular viewbox one could fully use the drawing area ...
Another thougt: Is it possible to control the z-order of the TechDraw parts? Let's say to move the template topmost?
(Of course I can do this by editing the exported PDF-file with inkscape for examle)
The complete assembly (ventilation of the housing of a traffic information sign):
