In the described workflow I came across another issue:
Is it true that TechDraw View isn't able to fully resolve relative positioning?
I createt an assembly with main and sub parts (first the 'classical' way - second started to rebuild it with Assembly 4 workbench). But in both cases the result is identical.
It is locically for me to set the 'z' property of the main part and to position subparts relative to the main part.
When I create a TechDraw View of the whole assembly all goes well.
The screenshot shows the result after changing the source of the view to solely 'MountingParts' to be shown ...
The Big TechDraw Comments Thread
- wandererfan
Re: The Big TechDraw Comments Thread
Thought we already had a ticket for this, but I couldn't find it. issue #4208
Re: TechDraw Comments from Feature Announcement
Hi Achim,bavariaSHAPE wrote: ↑Sun Oct 16, 2016 8:56 pmHello everyone,efyx wrote: 4) Tolerances I would see it as in "drawing diemnsioning" but with few addons.
7) Welding symbols - we can discuss how they should be created because there a lot of informations.
I have read the discussion about "shape and position tolerance symbols" here. The first symbols I have released in the meantime for the first test. Two editable tolerance fields are also available.
I tested the symbols with the last stable FreeCad 0.16 for Win 7. With the version 0.17 for Win 7 I had some problems.
I use the symbol library and the macro from yorik.
If the text in the editable fields has been changed, use the macro Macro Force Recompute.
In the next time, I'm going to create additional symbols, that are needed for different construction areas.
I do not know if these symbols can be used in the form. I just use it in a project.
Achim
please could you describe me how to use the macro and the svg library.
Please with some pictures for better understanding, and how to add to a Techdraw drawing.
Thank you so much.
Best regards
Wilfried
