The Big TechDraw Comments Thread
wandererfan
Re: The Big TechDraw Comments Thread
Postby wandererfan » Fri Oct 07, 2016 12:36 pm
user1234 wrote:I owe you a bugreport but at the moment i have no time ..... sorry.
I look forward to it. I've just about worn out the last test file you gave me. :)
f3nix
Postby f3nix » Sat Oct 08, 2016 5:21 pm
First of all I'd like to thank you all for a great work! It looks really good.
I don't know if it has been reported before but I think I've found a bug. Dimensions of an isometric view are not correct. Screenshot attached.
dimension bug.png (23.4 KiB) Viewed 2812 times
Cheers,
Mateusz
isometric view.fcstd
(33.34 KiB) Downloaded 45 times
NormandC
Postby NormandC » Sat Oct 08, 2016 10:09 pm
Dimensioning isometric views is a whole different ball game. I don't think wandererfan has implemented this yet.
It sure can be handy though. Back in 2007 I evaluated three mid-range parametric CAD modelers for the company I worked with. Dimensioning iso views was a feature we needed. Out of the three programs, only one had this feature IIRC. Things may have changed since though.
Until/if it is supported by TechDraw, maybe it would be best to disable dimensioning iso views? If that is possible.
wandererfan
Postby wandererfan » Sun Oct 09, 2016 12:02 pm
NormandC wrote:Dimensioning isometric views is a whole different ball game.
We tried to do this automatically, and it was a shambles. But you can certainly do it manually.
The link dimension tool allows you to assign an edge from the 3D view to a Dimension in the 2D view. Once linked, the actual (True) value will be used instead of the 2D (Projected) value.
LinkDimensionTo3DGeometryIcon
TruevsProj.fcstd
(18.66 KiB) Downloaded 54 times
f3nix
Postby f3nix » Sun Oct 09, 2016 2:55 pm
Thanks @wanderfan. It looks like a workaround.
dimension bug 2.png (19.38 KiB) Viewed 2749 times
One has to be careful since the lack of topological naming is showing its face again. After adding a fillet.
dimension bug 3.png (16.24 KiB) Viewed 2749 times
What is strange is that the dimension value has not been updated.
Cheers,
Mateusz
NormandC
Postby NormandC » Sun Oct 09, 2016 6:24 pm
wandererfan wrote:The link dimension tool allows you to assign an edge from the 3D view to a Dimension in the 2D view.
Thanks, but how do I use it?
After selecting an edge then creating a dimension on an ortho view, I tried to
  • Select the dimension then the corresponding edge on the iso view
  • Select the corresponding edge on the iso view, then the dimension
  • Select the dimension then the corresponding edge's vertices on the iso view
  • Select the corresponding edge's vertices on the iso view, then the dimension
Everything I do results in this error message
Can't link a dimension to this selection
Installed from the Daily Builds PPA:
OS: Ubuntu 14.04.5 LTS
Version: 0.17.8614 (Git)
Build type: None
Hash: a50bd5dc880f76c3ba8b7af5bd5d19799db4cbf1
Python version: 2.7.6
Qt version: 4.8.6
OCC version: 6.8.0.oce-0.17
NormandC
Postby NormandC » Sun Oct 09, 2016 6:42 pm
A couple of bugs which appeared lately (not sure which commit):
  • In the Insert Projection Group utility, Automatic scaling doen't work anymore
  • Neither does Custom scale, at least there is no more live preview. Scale is only applied once OK is clicked
  • After ticking the secondary projection checkboxes in that order: top, right, front top right, the secondary projections are all displayed like the first selection:
    It is only once OK is clicked that the views are properly displayed.
  • What exactly is "Document" scale? When selecting it, the projection group is scaled very small on the default A4 page.
    (I just now noticed that the dimension on the right view somehow got switched, it was linked to the bottom edge.)
Would you prefer I make proper bug reports on Mantis?
f3nix
Postby f3nix » Sun Oct 09, 2016 6:45 pm
NormandC wrote:Thanks, but how do I use it?
Hi @NormandC.
You have to select an edge in 3D view then switch to drawing and use the link function.
HTH.
Cheers,
Mateusz
NormandC
Postby NormandC » Sun Oct 09, 2016 6:55 pm
Oh! Thanks! I thought that by "3D view", wandererfan meant the iso view in the page. :oops:
EDIT: well it doesn't work for me. The linked dimension sees its value changed to 0.00mm. :?
I'm starting to wonder if there's something wrong with the Ubuntu Daily Builds package!
ulrich1a
Postby ulrich1a » Sun Oct 09, 2016 7:00 pm
There is a small bug in the creation of a projection group. The rear view is wrong at setting of the checkmark as can be seen in the projection of a Part wegde. The view gets right after changing force and back of the view direction.
Edit: I see Normand was faster than me!
Ulrich
OS: Debian GNU/Linux 8.6 (jessie)
Version: 0.17.8656 (Git)
Branch: (losgelöst von d39bd49)
Hash: a90907530fb42f2bf78b6532982976c15aa8511b
Python version: 2.7.9
Qt version: 4.8.6
projection of wedge with wrong rear view
